PDA
View Full Version : ? day time running lights
NothingFast
08-08-2006, 10:34 PM
I am going to install HID's in my 2003 S10 and I was wondering if anyone knew how to disable the day time running lights. Thanks in advance.
martz0r
08-14-2006, 12:28 AM
Turn on the parking lights.
lol, just kidding.
See that little panel door on the side of your dashboard where the door meets it? The left side... Open that panel I think there should be a black connection that you unconnect and you're good to go
sLaturn
08-14-2006, 09:24 PM
if you can find the optical sensor somewhere on the dash, just pull the dash up and unplug it
martz0r
08-17-2006, 02:28 AM
Daytime running lamps run 24/7. These aren't light-activated ones
Where did you go? Did you die? Because I want to know what happened.
Southern_SS
08-20-2006, 10:42 PM
just pull the relay??
Swampgoat
08-21-2006, 10:40 PM
That was first mod on my 04 GTO. Funny, the dealer put a new one in when I went in for tire rotate and balance. Now I have 2 in the glovebox. Most GM DRL relays live in the engine compartment fuse/relay box.
Ls1edit or HPTuner will turn it off too.
