PDA
View Full Version : Stocking Rota Arriving next week!
Xiwei
08-08-2006, 06:24 PM
1 set Rota JMag Black 15x7 4x100 $550 (PM for better pricing)
1 set Rota JMag Ab Polished 15x7 4x100 $550 (PM for better pricing)
2 set Rota D2 17x7.5 +35, 17x8.5 +35 in Black $700
Also, Used:
HX, set with tires! 275! MINT!
Rota Slip 15x7 Flatblack, $300 no tires!
Xiwei
08-15-2006, 10:55 AM
the rotas have arrived
http://image.aftermarketnoize.com/0/0/273/Image.jpg
Shadytrixta1
08-15-2006, 01:22 PM
Holy S*%! Are those Skyrine wheels too?
Griffin400
08-16-2006, 09:09 AM
no just old crappy wheels that nobody wants:lol:
NEWBORN240sx
08-16-2006, 09:15 AM
can you get the rota grid that are on hoursepowerfreaks.com for the nissan 16x8 +10 offset thanks
SpottedMango
08-16-2006, 11:05 AM
We sure can!
treekiller
09-03-2006, 11:04 AM
I need a set of rota's 17x7 42-47mm offset that can clear my brembo brakes on my Spec-V I have had too many sets get delivered ups only to call and have to send them back "they don't fit" and before you ask I know 35mm offset S13 wheels fit and clear hwever they are NOT legal for SCCA B-Stock. I'll take some S-13 wheels if we can machine the backspacing to accomidate the rule book. you are allowed to charge me a little extra for the trouble if your willing to help test fit some options.
Thank you
-TK on TR
LS1Fever
09-03-2006, 01:30 PM
Can you get rota subzeros in 16x7 *5x114.3* in gunmetal or black with a 40mm offset?
Xiwei
09-03-2006, 09:46 PM
Thank you
-TK on TR
i much doubt you will find a rota to fit in your need as their wheels are not available in every offset, for example, like a rays wheel. their wheels really only typically come in these offsets, +48, +45, +40, +35, +25, +15, +10
i have one set of 17x7.5 rota d2 in +35 and also i can test fit one set of rota 17x7.5 boost in +45 (the customer just picked it up, but i can arrange to have the wheels here for a test fit within the next few weeks, what has been the offset of the other rotas you've ordered? we maybe able to get the set of d2 on your car and also order a set of h&r spacers to fill out the rest of the remaining space so you are within the +42-47(i assume that's what the rule book want you to be in) if you have a chance, swing by and we'll have a look :)
edit: infact, if the normal wheels for a s13 fits, i am sure the d2 will fit because they are not offset by the face but instead material is built upon the back of the wheel, it should give a decent clearance on your brakes and we maybe able to get a 10mm spacers from h&r to put you at +45
currently, rota only has the 16x7 subzero 5x114.3 +40 in a royal silver there is more +45 selections if you don't mind +45, i can get you sports grey and royal gunmetal in +45, thanks
treekiller
09-04-2006, 11:14 AM
I think you have it reversed. I have positive offset by adding a spacer it's going to bring the offset lower. so a 35mm Wheel with a 10mm spacer would actually take the dynamic offset to 25mm or 10mm closer to a Zero offset. At this point if you would sell me a set of Volk TE-37's or anything that we know will fit. if we find a S13 (4x114.3 66.1 mm hub 35mm offset) wheel that has plenty of clearance, then we would have to find someone with a large lathe to cut back 7mm of material. I do not have rota's right now the last set of wheels I had sent to me were Team Dynamics Pro race 1.2 these will work for the rear of the car in a pinch but I am very upset with the companay that sent them to me. since I ordered pro race 1's which have much more brake clearance and are lighter. And I have no paitence for incompedence when it comes to getting the Correct race parts. 14 years racing 3 of which was operating my own shop. when I order somthing I expect it to fit. so you can understand my anger. and as for the 16x7's if I downgrade my car to a "standard" SER then I would need to run 16x6.5" wheels. and loose the 6 speed. it's not a good thing.
What rotas are the STI and Evo guys using to clear their brakes, since mine are G35/350z calipers there HAS to be a soloution. even if I have to pay.. I would go nismo/rays but they are 7.5" and thus illegal for SCCA.
treekiller
09-04-2006, 11:23 AM
and I don't care about color style etc etc. these are race parts. if they were clownshoe red with white polkadots I'd take them If it gets me to shave 1/2 a second off my lap times. and most everything I'm looking at is +45mm offset. since that's the standard replaement for the factory +47 and well within range. but they must be light. money is not my focus.
problems arise since you cannot compare 7.5" 35mm vs 7.0" 35mm since the 7.5 will have another .25 inch of clearance @ the identical offset. which you can measure away but the least obsticales the better. like I said. I'll take OZ's Volks anything that works and is light. some uber exotic japanese funk is fine too, as long as it works!
I actually like the idea of the JSPL rota even in that mint green color but it's f'in light. and mabye bright green wheels on an orange car is a statement.
Jeff
Xiwei
09-04-2006, 01:08 PM
typical evo and sti uses a +40 or a +45 but they typically run a 17x8
what does the rules require you to have? a 17x7 +42 to +47?
you are right, adding a spacer will take away fromt he offset, i was thinking reversed :p
let me look into it more tomorrow and i'll let you know
the volks or axis wheels will allow more brake clearance front and rear. what's the brake set up that you have?
treekiller
09-04-2006, 10:57 PM
They are nissan factory V-Specification Brembo race calipers. factory wheels are 47mm and the rulebook specifically states factory wheel width and diameter with +/- .25" in offset.(.25 x 25.4 = +/- 6.35 mm) so I really could go anywhere from a +40.65 mm to a +53.35 mm (the closer I legally get to the lower number the better) more track helps increase the dynamic caster and camber I am allready lacking adjustment and in stock class and will allow use of a 235mm front tire. it's these small changes that mean winning a national championship and driving back from topeka kansas with your tail between your legs. if we find a 40mm wheel that fits I'm okay with being .65mm out of wack If i'm that compeditive by next year i'll have them modified to within specs. you don't get protested if you don't win.
-TK on TR
LS1Fever
09-04-2006, 11:04 PM
How about 16x7 slipstreams or subzeros in black? 40 or 45 offset? 5x114.3? Also, what is the price? PM me please.
Skittle
09-04-2006, 11:08 PM
Those black J-Mags are fucking SEXY!
Shadytrixta1
09-04-2006, 11:10 PM
The machinist we use to drill rotors has some pretty cool machines, I can talk to him tomorrow and see what he could do to knock 7mm off a set of these wheels if your interested.
Xiwei
09-05-2006, 02:44 PM
more rotas will be coming into stock, rota c8, rota gt3, rota grid, rota rb
LS1Fever
09-05-2006, 06:51 PM
I havent received a PM about price. Let me know.
Xiwei
09-05-2006, 07:56 PM
completely left my head, i will check tomorrow, thanks!
treekiller
09-07-2006, 12:26 PM
any luck getting ahold of Buddy club?
4thgenhatch
09-11-2006, 01:52 PM
Still got the black jmags
Xiwei
09-11-2006, 03:53 PM
yes sir
4thgenhatch
09-11-2006, 08:57 PM
how much?
Xiwei
09-12-2006, 08:14 AM
how much?
pm'd
focuszts
12-07-2006, 10:02 AM
I've been trying to get a set of 17x7.5 royal silver rota grid wheels. I need a 4x108 bolt pattern which is hard to find.
rota grid: hyper silver
17x7.5
4x108
45mm offset
any chance you can get these?
Shadytrixta1
12-07-2006, 11:40 AM
I will give a call after 12 to see if I can get them.
focuszts
12-07-2006, 01:05 PM
ok thanks. I've been told 3.5 month wait by a retailer who didn't have them in stock.
focuszts
12-07-2006, 09:50 PM
any word yet?
Kirk
12-07-2006, 09:57 PM
Don't know if Cody has called yet but I will call tomorrow when they open and see if its on backorder.
focuszts
12-07-2006, 10:02 PM
ok. I was just quoted by another retailer at 60 days for custom order...and i'm looking for hyper silver. Its just my focus has a uncommon 4x108 bolt pattern
weeper
12-07-2006, 10:38 PM
whats your price on rotas circuit tens full polished 16 inch by 7 for a 95 eg civic !! thank You guys !!
focuszts
12-12-2006, 11:25 AM
no word on the 17x7.5 rota grids royal or hyper silver?
45mm offset
4x108 bolt pattern
Steez
12-15-2006, 03:40 PM
The black JMags are MINE!!! HA! HA!! HA!!!
SpottedMango
12-15-2006, 03:48 PM
Pitures?
Steez
12-15-2006, 03:57 PM
Pitures?
I need to take some, its just my camera batteries are dead so I'm charging them, then I need to wipe my car down and take some pictures of the 4x4 hotness.
Gracias Concepto Driveno
