battery relocation kit questions
Taylor box here as well, I only bought the box, get some 1/0 welding cable for the power wire, because its nice and flexible. The Optima battery hold downs look nice as well.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Ryan
Guest
Posts: n/a
Actually in my Golf I have a Jegs box. Its kind of cool, the lid is held on with flip latches.
But I hope I got a dud as far as the hardware goes, because only one hold down stud was the right size, the other was smaller than 1/4-20. And none of the nuts in the pack matched the studs?!
The Taylor lid is held down by the two studs that hold the battery in place. It has a pair of nuts that hold the battery down, then another pair that hold the lid on.
1/0 is a bit overkill. I usually use 2ga. There is a surplus place up here that sells Streetwires and similar stuff for cheaper than butying wire from the welding supply.
I went the cheap bastard way, and have the black plastic boat battery box (9-10$)....
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Guest
Posts: n/a
but unless you enclose the entire trunk with sheet metal 100%, its technically not IHRA/NHRA legal.
I dont know if that matters though. Back when I used to take my pinto to DeSoto I just had the battery laying in the spare tire well(hatchback). Didnt even had a tie down, it just slid around the well
I went to the marine store and bought a boat battery box and X-amount of 2ga power and ground wire to suit my application. batt box came with a pull strap to tie down the box. was actually very secure
image removed from your sig...see forum rules
