PDA
View Full Version : Half-built CRX vs. My New Setup
mrnicejetta
07-26-2006, 11:45 PM
Out in the boonies tonight there was a Harlequin CRX...
From what dude told me:
Stock 1.5 bottom end
Fully built dual cam head (larger valves, valve grind, stage III Crower cams)
Intake, header, and full exhaust
40/45 roll to 105/110, me up by a fender.
We stopped and chatted for a bit, and made sure we both had clean runs. Dude was cool, I forget whether he is on here or not. There were a few chaser cars behind us.
flashdiesel
07-26-2006, 11:52 PM
dohc head on a 1.5 block?
integra
07-26-2006, 11:53 PM
1.5 bottom end with a dual cam head...hahahh..good kill
mrnicejetta
07-26-2006, 11:56 PM
I know very lil' about Honda motors, I just regurgitated what he told me. He said the Crower Stage III cams were 276* Intake and 285* Exhaust, so I just assumed there were two. :dunno:
YBlegal
07-27-2006, 04:15 AM
the only way to put a DOHC head on a SOHC block is to use the ZC head wich is pointless, and i dont think crower makes cams for the ZC DOHC...and i dont know much about the SOHC cams crower makes...
YBlegal
07-27-2006, 04:20 AM
crower doesnt make a cam that has those specs.... Crower Cams & Equipment - Honda Camshafts - D16Y (http://crower.com/cat/import/honda/cams/d16y.shtml)
Crower Cams & Equipment - Honda Camshafts - D16Z (http://crower.com/cat/import/honda/cams/d16z.shtml)
Crower Cams & Equipment - Honda Camshafts - B Series VTEC (http://crower.com/cat/import/honda/cams/b_vtec.shtml)
Crower Cams & Equipment - Honda Camshafts - B18A/B DOHC (http://crower.com/cat/import/honda/cams/b18ab.shtml)
first 2 links are the SOHC cams, and the 2nd 2 links are the DOHC cams...
mrnicejetta
07-27-2006, 12:09 PM
Well shit, I have no idea. One other thing he said was he had a 9500 rpm redline. So who knows?
YBlegal
07-27-2006, 01:52 PM
SOHC vtec if built with valvetrain and stuff will go to 9500.....i was taking my GSR to 9600 for a lil while but then had the ECU reprogrammed for 9000rev limit
mrnicejetta
07-27-2006, 02:03 PM
I'll have him pop the hood next Wed. and find out for sure. It's got me curious now.
YBlegal
07-27-2006, 02:04 PM
:lol: ya check it out so you know for sure....
JR.
07-27-2006, 08:15 PM
i have seen f22 bottom end with h22 head....
mrnicejetta
07-27-2006, 10:32 PM
I was talking to someone else tonight who said it has an LS in it. There are 276/272 Crower stage 3 cams for that. If so that makes me feel a lil' better, but I'll see what's up with dude next Wed.
Teamcalloway03
07-28-2006, 06:01 AM
Good kill man..
AvASTi
07-28-2006, 05:27 PM
good kill nate!!!!!! vw ftw
hondahunter
07-28-2006, 05:47 PM
good kill
mrnicejetta
07-28-2006, 07:01 PM
Thanks guys, but today my CV's started acting up. Right now 1st and 2nd are pretty tempermental. I might be able to eek out a couple 3rd-5th runs. A friend of a friend wants to run me with his "stockish" TC. I said sure if he buys me a new driver's side axle when I beat him. We'll see what happens :dunno:
luvsracin87
07-29-2006, 12:16 PM
good kill with the dub....... i got some used axles if you want them..$10 you just got to pick them up.lmk
dscivicdx
07-31-2006, 01:52 PM
im not sure what you have done, but if that crx has an ls with a built head, its going to be deep into the 14's even with a bad driver. if your running a stock 16v and you won by a fender then its a 1.5l sohc.
im in no way knocking your car, but i had a 16v scirocco with i/h/e and my ls swapped civic is way faster.
mrnicejetta
07-31-2006, 02:53 PM
I never said I'm stock. I'm using factory parts, but not necessarily 9A parts. ;)
YBlegal
07-31-2006, 03:14 PM
:lol:
mrnicejetta
07-31-2006, 03:41 PM
Out of curiousity, how do you put an intake on a scirocco? You'd have to switch to digi or some stand-alone. Because there's that nasty fuel distributor sitting on top of the airbox, plus you only had the 1.8 in the scirocco unless you bumped up to a 3A/9A/ABA block.
dscivicdx
07-31-2006, 03:50 PM
pm me your setup if its not top secret. im very interested. i loved my scirocco, but back in 93-94 i could only get it to be reasonably quick.
