what are some of
Old Jul 17, 2006 | 01:20 AM
mitsu420aT's Avatar
Default what are some of
what are some of the basic mods that a 2g awd can do to the suspension and tranny ( welding ect...).. drive train i have read something about welding ...and hard to turn or something,,
what do you guys have done?
Old Jul 17, 2006 | 04:12 AM
THE_ONE's Avatar
*Turbo Interceptor*
Double synchro 1st gear gvr-4
Double synchro 2nd gear
Double synchro 3rd gear close ratio
Double synchro 4th gear close ratio
1st/2nd steel shift rail w/ forged rail end
3rd/4th steel shift rail w/ forged rail end
Steel output shaft retaining sleeve
Cryo treat all in tranny that is treatable
Enlarged oil passages.
Speed Design 4 spider center differential w/ thrust bearing upgrade
EVO shift forks w/ replaceable Bronze wear pads
All gears & shafts stress relieved and modified for durability.
Additional machine work can be done to improve durability and shift great.
Rebuild Matching Transfer Case
Old Jul 17, 2006 | 12:04 PM
mitsu420aT's Avatar
damn dude where i can i get all this done at ?
what about welding center drive shaft or some shit like that. i hear yall talkin about this all the time.
rep given thanx
Old Jul 17, 2006 | 12:36 PM
2gntTalon's Avatar
i think you mean welding the center diff. This link may give you some more insight http://www.dsmtuners.com/forums/showthread.php?t=173481
Old Jul 17, 2006 | 01:58 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Jerry can help you with all this.
SUCH IS THE RULE OF HONOUR.
Old Jul 17, 2006 | 02:43 PM
THE_ONE's Avatar
*Turbo Interceptor*
rep given thanx
Um no, don't weld shit. Thats the biggest mistake you can ever make on a daily driven car. "personal experience" Save up and get a 4 spider diff as listed in this list! Don't weld a diff... defenant no no
Jerry can do most of whats on that list, except the 3rd and 4th dual syncros.
you have to go to TRE for the rest
