PDA
View Full Version : faze tach super slim
96neonmike
07-12-2006, 10:09 PM
hey finally got a tach for neon its a actron faze gauge that goes up 2 10,000 rpms pretty easy install after i found the tach wire my neon didnt have one stock but made due since all neons have the tach wire anyone needs help hooking on up pm me or message me ill put the details and the pic of it finished up soon
and also if i have the time pics of how to install one the way i did it
well first i grounded the wire to the under dash frame about 6 screw or more to take off the plastic part and also the metal part ill get pics up soon next i put instead of going in to engine compartment i put the power wire for the shift light and tach light into the fuse box i got to look to see what ones i used and get pics of it also i splice wire on these wires and the last part was taking off the dash and taking out the guage cluster (mph gas ect) 4 screws. in the back you have two harnesses after you take out the cluster your going pop out the right one leave left one alone and look for the grey wire with a blue strip and go and splice in to it with the green wire which is the rpm wire after you get that dont test it before you put it back together then put it back together and your set :0 hope this is helpful now aslo i was going to put the wire for the tach slpicing into the dimmer like it says in the manual but i thought that i really dont need to dim it because it isnt very blinding bright just perfect hope this helps and will have pics up soon as i get the time-mike
HPNOTIQracing
07-13-2006, 08:32 AM
pics
96neonmike
07-14-2006, 10:44 PM
gotta find the cam tonight and ill start takin off parts and show you what i did should have pics by mid tmrw
SLEEPIN_92SE-R
07-15-2006, 08:51 AM
hey i got one of those faze tachs brand new jus sittin in my room how much you think i can get for it i aint using it and need some cash quick to fix my skittle and any little bit helps
ImportCorner
07-15-2006, 12:23 PM
20 buxs?
96neonmike
07-15-2006, 07:51 PM
brand new they cost 120-140 120 at aap without tax i work their so i got it for 100 but what kind is urs like reverse(black) or reg (white) the black one cost liek 20 more or sumthin im gunna get the morpher for it and im set to change it to a dif color good as tach tho sry dont got pics sis took the cam and screwed me over
SLEEPIN_92SE-R
07-17-2006, 04:33 PM
reg white brand new never installed
96neonmike
07-18-2006, 03:39 PM
thats the one i got id say sell it for 90 if its brand new even tho i bought mine for 100 from advance
96neonmike
07-18-2006, 03:53 PM
ight guys well i got the pics but comps being lazy so i got to wait till i get home tonight after work pics will be up tonight at 10ishas long as comp is not lagging as bad to upload the pics they have full detail on each pic on what to do and ill give you the wire set up on each pic also for the fuse box pic
estimated time say 30 mins tops
96neonmike
07-20-2006, 10:31 PM
pics finally up first take off ya dash then pics start after that
http://i5.tinypic.com/20jobv7.jpg
take the screws out of the left and right side of gauge cluster then pull it away should come off without much pull
http://i5.tinypic.com/20jof1t.jpg
http://i5.tinypic.com/20joffr.jpg
then pull up and then out the right connector in pic above^
http://i5.tinypic.com/20johms.jpg
ok this pic above is where the tach wire is it is a grey wire with a blue streak on it i used inline connectors that came with the tach worked great.
http://i5.tinypic.com/20johw7.jpg
just a pic of where i put the wires down to go to the fuse box in the side
http://i5.tinypic.com/20joi81.jpg
take off cover and also take the screw of the side
http://i5.tinypic.com/20jokkg.jpg
take out the 3 or 4 i thinks screws on bottom then pull of carefully the panel
http://i5.tinypic.com/20joktt.jpg
then i showed you where it stuck the wires through the side.after that take the 2 screws out of the side of the fuse bos and in the back of the fuse box pic at bottom
http://i5.tinypic.com/20jolkg.jpg
http://i5.tinypic.com/20joltt.jpg
take off the screw on the metal panel then pic of what to do in next pic
http://i5.tinypic.com/20jp6ki.jpg
then put it all back together and your finished hope it looks great and works goodhttp://i5.tinypic.com/20jp75g.jpg
HPNOTIQracing
07-21-2006, 09:01 AM
i just wanted a pic of the tach itself.
paint the chrome lip
also does the whole guage light up the faze blue/green?
96neonmike
07-21-2006, 06:50 PM
they make the lip in asorted colors so ima order one in red soon also yes the tach is blue at night ill take a pic of it tonight and show ya what it looks like its blue right now till i get the morpher for it which changes it from blue to green and all colors in between then 2
96neonmike
07-21-2006, 06:52 PM
also wanted to make instructions for everyone with a dodge neon that didnt know how to do it thats y it took so long to get pics up and hope it helps out some neon owners or any dodge chrysler car:)
neondriver
07-24-2006, 11:44 AM
tepp thats the best way to do it. i installed a tach in both my neons and did it the same way. my light in my white car was hooked to my dimmer but in my red car its just spliced to my ignition "on" wire.
