PDA
View Full Version : nitrous question/audio for my gm. any info helps
chevy94cav
07-03-2006, 06:35 PM
ok i am woundering here i have a nitrous heater for my bottle. instead of running it all the where to my batt. then to a switch in my cab do u think i could run it to my amp in my trunk? power to memory wire and ground to ground? would this work so my heater would always be on while my amp was on which means everytime im in my car it would be on no extra switch's? pls any info would be helpful thanks....
HybridSS
07-03-2006, 11:00 PM
No...yuo dont want to do that. You need to be able to turn the power off when the pressure gets to a certain psi. On a new bottle it wont take 10 minutes to get the pressure up to high levels. After a while they can get to dangerous levels. Better yet a pressure switch to control the on/off is tghe way to go. Go to www.dynotune.org and check out some of thier heater products. they have a special every once in a while for a complete heater with pressure switche and wiring for $99. Thats the best deal going anywhere.
chevy94cav
07-04-2006, 03:52 AM
ok i'll look into it .... i alrdy have the heater pad but it didnt come with no switch or anything else..... i didnt realize it only takes a few minutes to get up to 1050psi.......
chevy94cav
07-05-2006, 07:31 PM
chevy94cav
07-06-2006, 07:19 PM
any more info
chevy94cav
07-07-2006, 04:39 AM
Jed Z06
07-07-2006, 11:42 PM
Do you have a defrost heater in the rear window?
You can grab 12 volts from that, And turn it on and off with the rear defrost switch on the dash!
DANGERANGER
07-17-2006, 11:08 PM
NO! do it the right way or buy a bag of marshmellows for when it burns!
chevy94cav
07-22-2006, 02:06 PM
jed z06 thanks for the info...... and also dangeranger i bought a bag of marshmellows when i put nitrous in my car wont know when u'll need them...
chevy94cav
07-22-2006, 02:07 PM
yea ive seen some pictures of a mustang the guy left his heater on over nite morning time it blow his trunk off
Country Boy
07-24-2006, 02:18 PM
+1
Just do it the right way or you may wish you would have.
DANGERANGER
07-25-2006, 12:57 PM
I won't need them, thats for sure. If there is going to be a fire in mine its because I got greedy with it, not because of poor install.
chevy94cav
07-25-2006, 02:17 PM
yea my nitrous was installed by real speed. the main point of this thread was to see if theres an easyer way of running the heater im just tryin to cut back from having tons of switchs.. purge, nitours,now heater, bass boost control,fog lights, neon lights its just getting really bad...lol running out of openings for switchs. i feel like im driving an airplane
