PDA
View Full Version : Do you clean your helmet?
w0rd
06-29-2006, 06:00 PM
If so, what is your technique?
Muddy
06-29-2006, 06:09 PM
Ha! I have never thought of it. It doesn't stink, so I am happy! :lol:
D-Roll
06-29-2006, 06:37 PM
I haven't had to do that yet, but whatever you do don't put the inserts in the dryer.
jlude90
06-29-2006, 07:02 PM
i don't have one to clean, so i'll let you know in a few years
Alizarin
06-29-2006, 11:09 PM
I wipe the shell off with a rag before I leave in the morning for an event... that's about it so far. Then again, it hasn't even seen a year's worth of use yet, and I only use it once or twice a month.
Mars_302
06-29-2006, 11:34 PM
Shell Cleaning
Only use approved methods to clean the helmet. Using other unapproved chemicals or methods may damage the helmet shell or lining. A damaged helmet may increase your risk of serious injury or death in an accident.
Glossy Finish. HJC recommends cleaning your helmet with products designed for automotive cleaning and polishing. All HJC helmets are finished with an automotive type base coat/clear coat finish. Rubbing compounds can be used for deep cleaning to remove many scratches and scuffs. Follow the product's instructions diligently. Over polishing with rubbing compounds can cause light abrasions which may dull the finish of your helmet. Stickers and decals will leave adhesive residue when removed. To remove the adhesive residue, use alcohol swabs. Be certain to immediately wipe away the excess liquid and clean the area with soap and water once the adhesive residue is removed. Do not use excessive pressure while rubbing when attempting to remove the adhesive residue, instead use multiple light treatments.
Non-Glossy Finish. For our flat finish (non-glossy) helmets, we recommend using warm water and mild soap. Use multiple treatments for heavier dirt. Do not use excessive pressure or rubbing compounds while cleaning the surface as a "glossy" effect could be created, ruining the flat finish appearance.
Interior Cleaning
Although we recommend changing a helmet every 3 to 5 years, the accumulation of sweat, humidity, and dirt can deteriorate the fabric and stitching and this may cause odor. To wash HJC removable pads, HJC recommends regular machine washing and air drying. (Removable interiors are available in models: AC-10, AC-11, AC-12, AC-2M, AC-3, CL-SP, CL-14, CL-15, Sy-Max, CL-Max, AC-X1, AC-X2, AC-X3, CL-X4, CL-X5, CS-X4, and CS-X2). For non-removable interiors, HJC recommends using bacteria and mildew eliminating products such as "Helmet Fresh".
Vent Cleaning
Dirt and debris can find its way into the venting of your HJC helmet. Compressed air cans used for cleaning computer keyboards may be used to blow the debris from the ventilation system. It is recommended that you remove any removable pads before doing this process.
mofugga
06-30-2006, 07:17 AM
so it looks like i'm gonna wax my helmet the next time i wax my car :lol:
Spin Out
06-30-2006, 07:52 AM
I empty about a half a can of lysol into the interior after each event.
OK not half a can, but I douse it well and let it air out on the kitchen table for a few days.
I could care less about the outside; chicks did scars.
