PDA
View Full Version : Hks Bov
Country Boy
06-23-2006, 09:21 PM
HKS Racing BOV $150 shipped
Only has <100 miles. HKS Racing Bypass valves are push type valves that utilize calibrated spring pressure and vacuum line pressure to remain closed against the pressurized air in the charge pipe. As the throttle is closed, creating vacuum in the line, combined with the force of the pressurized air in the charge pipe, the bypass valve pushes opens and allows the pressurized air to escape. The HKS Standard Bypass Valves are adequate for the airflow. HKS Racing Bypass Valves function similar to the Standard Bypass Valves, but incorporate an additional pressurized port to aid under severe boost conditions. The Racing Bypass Valve can also be used as a safety "pop-off" valve if the second port is connected to a pressure source that does not see vacuum. For added flexibility and function, HKS Racing Bypass Valves are offered in various adjustable boost pressure ranges that are determine by a specific spring pressure.
http://img.photobucket.com/albums/v614/01NastySS/My%20car%20and%20stuff/HKS2.jpg
[IMG]http://img.photobucket.com/albums/v614/01NastySS/My%20car%20and
turbo-max
07-23-2006, 12:51 PM
ttt, for the the homeboy
Country Boy
07-25-2006, 06:52 PM
thanks brah! Someone buy this thing!
