View Full Version : Radio doesnt work... help?
I Like Hondas
06-18-2006, 12:39 PM
I bought a car an it has a cd player installed but its not getting power, nor is the cigarette lighter. Anyone know how to get power to it?
TJElite
06-18-2006, 12:56 PM
Sounds like a fuse, since the cig lighter and radio constant are often on the same one.
Fuse might be called cig ligt, radio, or something like that. If you have a manual for the car, it usually lists all things powered by each fuse. Worst case, you'll need to check them all. This fuse is probably 20 amps...15 minimum, so you can narrow down your choices.
Toby
I Like Hondas
06-18-2006, 01:47 PM
Thanks dude! That would be awsome if that was all it was.
TBSpyder
06-18-2006, 02:02 PM
I vote for fuse.
I Like Hondas
06-18-2006, 02:09 PM
That woulda been awsome if it was, but I just checked 'em all. Any other tips?
TBSpyder
06-18-2006, 02:19 PM
Re-check them all with a multi-meter. Just because a fuse "looks" good doesn't necessarily mean it is. Check every fuse box as well.
I Like Hondas
06-18-2006, 02:38 PM
Its a crx I think it only has one fuse box. I don't have a multi-meter, but I do have some spare fuses I could just replace them all???
TBSpyder
06-18-2006, 03:14 PM
Use a single 20amp fuse and swap one at a time until it works. If I'm not mistaken, those Honda's are know for blowing the fuse when an aftermarket deck is installed. Whatever size fuse it is, I'd replace it with one that is about 5 amps larger (so if it's a 15 amp, put a 20 amp in there).
I Like Hondas
06-18-2006, 03:33 PM
oh thanks! that would make sence because its a sony deck. But should i replace every fuse with on higher? I only have about 7
usually those fuses come in packs of like 3 or 5, and cost at the max like $1.25, they're cheap as hell, go get a few and store em for a rainy day
I Like Hondas
06-18-2006, 03:43 PM
good idea!
Notladstyle
06-18-2006, 04:01 PM
whoops nvm its a sony, replace with 5 amps down. just kidding..
eh even with a sony it wont hurt to have 10 extra amps ;) he might decide to upgrade to a real cd player one day
TBSpyder
06-18-2006, 05:37 PM
No, you don't need to replace every fuse because more than likely it's only one bad fuse. Get yourself one good 20 or 25 amp fuse, unplug a fuse from the fuse box, plug the good one in, see if it turns on, if not replace it with the old fuse...go on to the next one. Get it?
If you want to spend a few bucks on all new fuses though, knock yourself out...but then again it may not be a bad fuse, in which case you just wasted a couple bucks.
I Like Hondas
06-18-2006, 08:05 PM
Thanks I'll go out and try it soon. Then I'll post what happnes
TBSpyder
06-19-2006, 10:31 PM
And?
Notladstyle
06-19-2006, 10:44 PM
And?
... and the ricer in him took over so he gave up and just went to walmart and bought a boom box to sit in the back seat.
bahaahhahahaahahhaha:lol:
Sadly enough i actually had a friend who did that when his stereo crapped out too. It was probably the worst thing i ever heard in my life. It was one of those boomboxes from back when we were all kids and thought it was the most awesome thing to plop one up on a shoulder and walk around like that.
I Like Hondas
06-21-2006, 06:23 PM
haha! NO I did not go to Wal-Mart and get a boom box, I got it at Bestbuy. Just kidding. I went out and tried all the fuses and none worked. Unless the car has another fuse box I dont know about that isn't the problem.
Notladstyle
06-21-2006, 06:25 PM
check under the hood for a fuse box and if there is none or none blown then just run a new wire 12-14ga for hte radio and the cig lighter. Dont pull the stock wiring, just crimp in the new power line and see if both get power - if they do they the line may have just been cut somewhere.
If you cant do that then lmk and ill do it.
I Like Hondas
06-21-2006, 08:31 PM
Okay so I found another fuse box under my steering wheel to the left and there's a crap load of fuses.
I tried pretty much all of them with new fuses, found 2 10's burnt out but that still didn't fix my problem, it also looks like there may be a couple fuses missing but I don't know what amps would go there.
I took a couple of pictures, maybe someone can take a picture of there's so I have a diagram of something to work with?
The one under my hood
http://i25.photobucket.com/albums/c60/drkno/carfusebox1.jpg
The one under my steering wheel
http://i25.photobucket.com/albums/c60/drkno/carfusebox2.jpg
And btw NoTLaDStyle I have no idea how to do the wiring =D
He does stuff for cheap...really cheap.... like Nebraska Avenue whore cheap.
speaking of which, i heard somewhere that if you dont have any cash he'd be willing to exchange sexual favors...
I Like Hondas
06-21-2006, 11:47 PM
Hmmmm. A very good thing to know.
I Like Hondas
06-22-2006, 12:27 AM
But ya... Anyone have any suggestions?
Notladstyle
06-22-2006, 12:53 AM
if its not fixed by the next time I'm in clearwater I'mm bring a meter and a light and figure it out.
GradeA_TireFryer
06-22-2006, 01:09 AM
Fuse Under The Hood!!!, Seen It A Million Times (ok Not A Million But A Lot)
And They Always Look Good- You Have To Meter Them
dsmdreamer
06-22-2006, 01:22 AM
u can go to the public library and look up the fuse diagram on the car for free it will tell u which fuse to use and where to find it. if its not a fuse its the wireing on the radio itself.
I Like Hondas
06-22-2006, 06:21 PM
The library???? No shit? I'll look into that. and NoTLaDStyle your welcome to check it out if your in clearwater just pm me and I'll give you my phone number. But I would prefer paying you in cash and not sexual favors.
Notladstyle
06-22-2006, 07:23 PM
I GUESS that will be ok, I was really looking forward to trying out this new leather whip...
I should be down saturday so if its still not working ill check it out then.
TJElite
06-25-2006, 09:59 PM
Take the umbrella...he'll change his mind...
Toby
Toby
Shit, i would if i saw Dalton with that umbrella again :hump:
Notladstyle
06-25-2006, 11:58 PM
wait, what did i miss with the umbrella? (rip it died today, 4 years old)
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
