PDA
View Full Version : Kia sephia Window Crank
Notladstyle
06-15-2006, 10:57 PM
Cant get the fucker off, its really pissing me off.
I've never done a manual crank that was this hard to get off, wheres the part at - checked autozone and discount they were both clueless as to what i was talkin about.
KartRex
06-15-2006, 11:40 PM
You need the tool....they have them at Adance auto parts.... i used to work there not shure what it is called tho...
Notladstyle
06-16-2006, 01:07 AM
why cant they mak it easy like ford does... plastic cover.. one bolt and its off.
Damn japanese engineering.
KartRex
06-16-2006, 02:26 AM
haha rice enginering
93ex
06-16-2006, 07:54 AM
Isnt Kia korean?
I've had a lot of crank windows need the tool, or at least screwdrivers, to get teh retaining clip out.
TJElite
06-16-2006, 09:51 AM
There is a wire clip that needs to come out. If you wedge something between the door panel and the handle, you should see it. Its kind of shaped like an ohm sign. Get a pick, or something, and pull it out. Once you get one off, and see how it works, you'll never have a problem again.
Toby
TJElite
06-16-2006, 09:53 AM
That tool is not as easy to find as it used to be, and, imo, is not so great. its not all that easy to use, and can muck up the crank, the shaft, and / or the door panel.
Use a pick, needle nose, or take a flat screwdriver and bend the end 1/8" to 90 ish degress.
Toby
TBSpyder
06-16-2006, 01:12 PM
Toby
It's the Jesus clip......alpha and the omega!
TBSpyder
06-16-2006, 01:15 PM
Toby
Yeah....and then PING! Flying clips. Be careful, those clips move faster than an illegal alien crossing the border. Cup your hand or something over the area the entire time.
TJElite
06-16-2006, 01:49 PM
That's where the name 'Jesus clips' really came from. Also often known as 'Damn Clips', F'in Clips, and 'WTF was that?!?!'
Toby
Notladstyle
06-16-2006, 04:51 PM
Toby
Roger, will be trying to get it off tomorrow. I actually got someone willing to pay me to build a box that fits their trunk :p so happy.
TJElite
06-16-2006, 07:08 PM
"A" Box? Like only one? Can you do that?
Toby
Notladstyle
06-16-2006, 09:46 PM
Toby
its gonna be hard, but i THINK I can get it right with just one...
mbanks21
06-17-2006, 05:36 PM
Whats a window crank?
P057
06-17-2006, 05:57 PM
those ancient devices people used to use to roll down windows... usually you rotate it in a clockwise/counterclockwise fashion in order to roll the window up or down. :lol:
I miss those buggers
Notladstyle
06-17-2006, 07:56 PM
Thanks to good advice from John & Toby I figured out how to get the clip off - After I got it off I was like oooh ok now I get it.
Unfortunately he bought5 1/4" speakers instead of the needed 6 1/2" so I had to cut panels but they turned out very clean - the outer rim of the speaker basket sat flush with the OEM mounting hole. The midbass was nonexistant though so the w0s will have to carry the slack.
I am concerned a little about water swelling the paneling but for $30 I think he got a deal anyways. Note the quality soldering ;)
KartRex
06-17-2006, 08:47 PM
Nice....
