help!!
Old Jun 13, 2006 | 12:05 PM
neondriver's Avatar
Default help!!
started my car and went to work...almost to work (10 miles) my car was just below 1/4 tank of gas. i got in the turn lane and it stalled. i went to start it and all it did was turn over. i got it home and added new spark pluggs, iso-heat in the gas incase i went through a puddle, i put my coil from my other neon tyhat i know is good and still nothing. it is geting gas, not sure about spark yet...an possible ideas? it does turn over bt doesnt start, i had it backfire a cople times earler causing a small shot of flame out the throttle body, i also used quick start and still nothing....im out of ideas and could use any help...
thanks
Old Jun 13, 2006 | 12:20 PM
neondriver's Avatar
so i unplugged the injectors and turned it over...got a loud backfire....then turned over again for a while and nothing..plugged the injectors back in and still nothing WTF??
Old Jun 13, 2006 | 02:39 PM
SlowAssNeon's Avatar
Typical Peon Owner
check spark. im thinkin youve got none.
Flying burritos? Brilliant!
Old Jun 13, 2006 | 07:05 PM
neondriver's Avatar
spark is weak and spratic when it does happen...coil id good though..what else could cause no spark
Old Jun 13, 2006 | 07:14 PM
BlackWind's Avatar
Requiem
bad grounds/wiring harness/pcm/anal demons.
okay
Old Jun 14, 2006 | 04:14 AM
Dano Moparo's Avatar
Grandpa
pcm/crank sensor/cam sensor
Old Jun 14, 2006 | 08:25 AM
neondriver's Avatar
wouldnt the sensors throw a code? the only codes i got have really no major impact on the motor running wise.
Old Jun 14, 2006 | 08:43 AM
neondriver's Avatar
so today i got no spark...
Old Jun 14, 2006 | 09:41 AM
Grandpa
what codes did you get?
Old Jun 14, 2006 | 12:57 PM
neondriver's Avatar
only code was battery dicsconnected within last 50 key on cycles
