BucsFanatic59
06-07-2006, 06:55 PM
Got everything you need.
Clutch pedal,master cylinder,slave cylinder,possibly hydraulic lines,flywheel,act 3200 clutch,throwout bearing,tranny with 102k miles(no problems),brace for crossmember. shifter assembly.
500 takes it all. You don't need the ecu, because you can run a 5sp car on the auto ecu I'm pretty sure. If you want it however, I'll let it go for 50 bucks extra.
