PDA
View Full Version : JL Audio E2150 Amplifier & Alpine CDM-9821 F/S
LS1Fever
05-20-2006, 11:17 AM
EVERYTHING SOLD!
(JL Audio E2150 Amplifier) $150
Key Features
Absolute Symmetry™ Class AB Circuit
(U.S. Patent #6,294,959)
Differential, Noise-Cancelling Input Topology:
RCA jack inputs (low-level) and multi-pin jack (high-level)
On-board Crossover:
State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency
selection from 50 – 200 Hz. Configurable as Low-Pass or High-Pass
Preamp Output:
Pass-through type.
Speaker output connections:
Accept up to 8 AWG wire
+12V and Ground connections:
Accept up to 4 AWG wire
Specifications
Rated Power (stereo):
75W RMS x 2 @ 4 ohm (12.5V);
150W RMS x 2 @ 2 ohm (12.5V)
Rated Power (bridged):
120W RMS x 1 @ 8 ohm (12.5V);
300W RMS x 1 @ 4 ohm (12.5V)
THD at Rated Power:
<0.08% @ 4 ohm (20 Hz - 20 kHz)
S/N Ratio:
>104 dB referred to rated power (A-weighted, 20 Hz – 20 kHz noise bandwidth)
Frequency Response:
10 Hz – 25 kHz (+0, -1dB)
Damping Factor:
>200 @ 4 ohm per ch. / 50 Hz,
>100 @ 2 ohm per ch. / 50 Hz
Slew Rate:
± 22V/µs
Input Range:
200mV – 8V RMS
Dimensions:
9.8" x 9.25" x 2.36"
(Alpine CDM-9821) $100 **SOLD**
Alpine 45 watts x 4 In-Dash CD Player (CDM-9821)
45 watts x 4 peak power: The internal amplifier pumps out plenty of power to your speakers for great sound.
CD-R/RW playback: Play the CDs you burned at home while you're on the go.
One pre-amp output: Add an amplifier with the pre-amp output to run more power to your speakers or a subwoofer.
Bass Engine®: Adjust the treble, bass and subwoofer levels for the best blend of sound.
CD changer controls: Built-in changer controls let you control an external CD or MD changer from the in-dash player.
Detachable faceplate: Remove the faceplate for added security when you leave your vehicle.
Will sell both for $225.
Gloveman1386
05-20-2006, 11:42 AM
Thats a good amp!!!! :wink:
LS1Fever
05-20-2006, 12:49 PM
I tested it out in a friends car and this amp rocks. Didnt even have the gain turn half way up with the bass boost off and this thing pounded 2 10" subs like no other. I was impressed.
LS1Fever
05-20-2006, 12:50 PM
Will consider trades, depending on what it is.
Gloveman1386
05-21-2006, 07:33 PM
Sell it back to me for what you paid me for it??? I want it back :lol:
LS1Fever
05-22-2006, 02:21 AM
Just because its you. Just call me up.
Gloveman1386
05-22-2006, 10:56 PM
Haha thanx man, that means alot to me :lol:
LS1Fever
05-22-2006, 11:13 PM
It better. :lol:
LS1Fever
05-26-2006, 06:33 PM
Buy me!
Koolaidy
06-07-2006, 05:52 PM
if it rocks, i will buy 8101881
LS1Fever
06-07-2006, 07:29 PM
Alpine SOLD!
JL Audio PENDING tonight.
