View Full Version : Drfting Technique
*Ryan*
05-11-2006, 05:17 PM
Thank you to Drift Session for the Info.
Also Stolen From War*uyoi.com
1:HEEL TOE SHIFTING
Heel toe shifting is a race shifting technique that allows drivers to downshift quickly while applying the brakes. Proper heal toe shifting keeps the engine, transmission, and wheel speed matched up so there is no jolt through the driveline while downshifting. When drifting, heel toe downshifting allows drivers to downshift in order to increase engine rpm, while braking to transfer weight forward and off the rear wheels.
http://i30.photobucket.com/albums/c308/motogpguy/Drifting%20Tech/HT1.jpg
1. Before entering a turn, do your initial braking to transfer your vehicle’s weight forward. Double clutch / heel toe downshift (see next step). Turn your wheels into the corner. Carry enough momentum into the corner to induce oversteer.
http://i30.photobucket.com/albums/c308/motogpguy/Drifting%20Tech/HT2.jpg
2. Clutch in, bring your vehicle into neutral, and release clutch. While on the brakes, slide your right heel over to the gas pedal and rev up (blip) the engine to match transmission and engine speed. Without matching revs on downshift, the engine speed will cause a jolt through the driveline, upsetting rear traction uncontrollably.
http://i30.photobucket.com/albums/c308/motogpguy/Drifting%20Tech/HT3.jpg
3. After matching revs, clutch in, and downshift your vehicle. Double clutching is optional, but reduces wear on your transmission. Use e-brake if momentum and downshift do not create enough oversteer.
http://i30.photobucket.com/albums/c308/motogpguy/Drifting%20Tech/HT4.jpg
4. Release the clutch, get off the brakes, and press the accelerator. Accelerate enough to keep tires spinning to continue oversteer. Add steering input (countersteering) to keep your vehicle from pivoting or spinning out.
*Ryan*
05-11-2006, 05:18 PM
2: POWER OVER DRIFT
1. Enter a turn at any speed. The powerover drift is based on horsepower so it does not necessarily need much speed or rotational force to perform.
2. Turn your wheels sharply into the turn, and get on the throttle enough to cause your wheels to lose traction. The cornering force of the vehicle combined with the excessive throttle will cause your vehicle to oversteer.
3. When you feel the vehicle’s rear end kicking out, immediately countersteer the wheels to face straight with the road. Your vehicle will pull in the direction of the front wheels, as long as the wheels are still moving. Keep on the throttle. If you press the brakes or let off the throttle because your vehicle is in an extremely oversteered condition, you will spin out or leave the road.
4. When you wish to straighten out your car, after completing the drift, let off the throttle smoothly and straighten out the wheels as your vehicle kicks in line behind the front tires.
*Ryan*
3:E-BRAKE DRIFT
1. Enter a turn at a speed too high for the vehicle to handle (if you do not drift, your vehicle should experience understeer at this speed).
2. Heel-Toe Downshift to get your vehicle into a gear low enough to pull you through a drift (2nd gear).
3. Turn your wheels sharply into the turn. By the time you finish downshifting and turning your wheels, you should be at the apex of the turn.
4. Hold in the release button on your E-Brake and pull up your brake sharply, then quickly release (e-brake is held up for only about 1 second). If using a RWD car, clutch in while pulling your E-Brake. If using a FWD car, keep on the throttle while pulling your E-Brake.
5. When you feel the vehicle’s rear end kicking out, immediately countersteer the wheels to face straight with the road. Your vehicle will pull in the direction of the front wheels, as long as the wheels are still moving. Keep on the throttle. If you press the brakes or let off the throttle because your vehicle is in an extremely oversteered condition, you will spin out or leave the road.
6. When you wish to straighten out your car, after completing the drift, let off the throttle smoothly and straighten out the wheels as your vehicle kicks in line behind the front tires.
*Ryan*
05-11-2006, 05:19 PM
4:CLUTCH KICK DRIFT
2. Turn your wheels into the turn and stay on the throttle.
3. At this speed, your vehicle should start to experience understeer. When this happens or right before this happens, clutch in, but stay on the throttle.
4. By clutching in and staying on the throttle, your engine will now rev up to high rpms. As soon as this happens, dump the clutch, causing your rear wheels to break traction.
*Ryan*
5:SHIFT LOCK DRIFT
2. Turn your wheels into the turn and quickly downshift into a lower gear (2nd gear).
3. By quickly downshifting (but not Heel-Toe Downshifting) you will put stress on the driveline, causing the vehicle to slow down and your engine rpms to increase.
4. After downshifting, quickly get on the throttle causing your wheels to break traction, sending your vehicle into a drift.
*Ryan*
05-11-2006, 05:20 PM
6: DIRT DROP DRIFT
1. Enter a turn at low to medium speed.
2. Turn your wheels into the turn and stay on the throttle, but drive slightly off the roadway with the side of your vehicle opposite of the turn you wish to make. (ex. if you are turning left, let your right side wheels drop into the dirt)
3. When your rear wheel goes off the roadway, the low traction surface should cause your wheels to break traction. Stay on the throttle as your vehicle returns to the roadway to continue the drift.
4. When you feel the vehicle’s rear end kicking out, immediately countersteer the wheels to face straight with the road. Your vehicle will pull in the direction of the front wheels, as long as the wheels are still moving. Keep on the throttle. If you press the brakes or let off the throttle because your vehicle is in an extremely oversteered condition, you will spin out or leave the road.
5. When you wish to straighten out your car, after completing the drift, let off the throttle smoothly and straighten out the wheels as your vehicle kicks in line behind the front tires.
*Ryan*
7: FEINT DRIFT
1. On approach to a turn, steer your vehicle away from the direction of the turn you wish to be made. The distance you begin to turn your vehicle away from the turn depends on how fast you are traveling. When you turn your vehicle away from the direction of the turn you want to make, you are loading up your suspension on one side of your vehicle, compressing the springs so that when you turn in the opposite direction, your vehicle will "bounce" back to its desired direction.
2. Once your suspension is compressed on the side of your vehicle opposite of the turn you wish to make, quickly turn back in the opposite direction. This feint motion should be done smoothly, but not necessarily quickly. Turning your wheels too quickly in opposite directions will cause your vehicle to understeer.
3. After rebounding your vehicle back into its desired direction, get on the throttle. When combined with the rotational force of the rebound, the excessive throttle will send your vehicle into a drift. FWD vehicles can use the E-Brake instead of the throttle to induce oversteer.
*Ryan*
05-11-2006, 05:21 PM
8: JUMP DRIFT
1. Enter a turn at medium speed.
2. Turn your wheels into the turn and stay on the throttle, but drive the inside wheels of your vehicle over a low curb.
3. When your rear wheel bounces over the curb, stay on the throttle. When your wheels return to the road, they should be spinning faster than what available traction can handle, causing your wheels to break traction. Stay on the throttle as your vehicle begins to drift.
*Ryan*
05-11-2006, 05:22 PM
9: BRAKING DRIFT
2. Heel-Toe Downshift to get your vehicle into a gear low enough to cause the rear tires to break traction when you accelerate (2nd gear).
4. Accelerate hard, but balance the throttle to maintain the drift.
*Ryan*
05-11-2006, 05:23 PM
10: KANSEI DRIFT
1. Enter a turn at high speed. The Kansei Drift should be performed at race speeds. (if you do not drift, your vehicle should experience severe understeer at this speed).
2. Turn your wheels sharply into the turn, and let off the throttle quickly. The cornering force of the vehicle combined with the loss of throttle will cause your vehicle to oversteer.
3. When your vehicle begins to lose traction, get on the throttle again quickly. This will overpower the wheels for the traction that is available, sending your vehicle into a drift.
*Ryan*
11: LONG SLIDE DRIFT
1. Enter a turn at high speed to perform this drift.
2. Turn your wheels into from the turn.
3. Hold in the release button on your E-Brake and pull up your brake sharply, then quickly release (e-brake is held up for only about 1 second). If using a RWD car, clutch in while pulling your E-Brake.
5. If your vehicle begins to lose speed while sliding sideways, heel-toe downshift into a gear low enough to pull your vehicle through the drift.
*Ryan*
05-11-2006, 05:24 PM
12:SWAYING DRIFT (CHOKU-DORI / MANJI
1. Enter a turn at medium to high speed to perform this drift.
2. Turn your wheels away from the turn.
5. Your vehicle will now be sliding sideways in an angle away from the turn you wish to make.
6. When you want to turn your vehicle back into the direction of the turn you wish to make, let off the throttle quickly and completely. By letting off the throttle quickly, your vehicle will snap back in the opposite direction. Once your vehicle is at its desired angle, get on the throttle again to maintain the drift.
7. Let go of the steering wheel so that your vehicle's wheels line up with the road again. Countersteer if necessary.
8. If your vehicle begins to lose speed while sliding sideways, heel-toe downshift into a gear low enough to pull your vehicle through the drift.
9. When you wish to straighten out your car, after completing the drift, let off the throttle smoothly and straighten out the wheels as your vehicle kicks in line behind the front tires.
Somebody wants the 25 bucks.. :)
*Ryan*
05-11-2006, 05:39 PM
^ okay????
ph0tek
05-11-2006, 05:44 PM
I dont think he was putting it up for the contest, =)
*Ryan*
05-11-2006, 05:55 PM
what contest ????????? and REY is kicking everyones ass on drift post right now!!!
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
