PDA
View Full Version : '02 stereo wiring
spddmn20
05-07-2006, 10:14 PM
Hi all trying to install line output convertor in 2002 monte carlo ? is none of the wires on harness are labeled and im trying to find a diagram for radio,or if anybody has done these and know what colors to splice into any info is appreciated!
Notladstyle
05-07-2006, 10:37 PM
Yelow & brown are left
Light blue and blue are right
If you have the bose system its possible to tap the line outputs behind the amp and get a clean signal.
Pull the fuse box, unclip the fuse mount and find the teal colored wire connected to the RAP relay and use that for the remote on wire. solder it.
Run the power cord on the passenger side - near the blower motor there is a grommet that the vacume line and a harness that runs to the engine where you can get a 4ga through.
spddmn20
05-07-2006, 10:53 PM
thanks alot which are positive/negative
Notladstyle
05-08-2006, 02:04 AM
GM is racist - the lighter colors are always negative. I dunno why I pulled the race card but yeah.
GradeA_TireFryer
05-08-2006, 08:28 AM
Mexicans Again !!!!
