PDA
View Full Version : kenwood kac-9152 always cutting out
samakaballer
05-02-2006, 12:44 PM
been checked 2wice,, it's hooked up correctly nothing wrong,, i just think the subs aren't powerful enough cuz,, the amp always goes into protection mode ,, not overheating because the amp is barely hot,, do yo uthink it's possible that those kenwood amps know ur subs can't handle the power and r ready to blow???? lol,, there's really no other explanation
samakaballer
05-02-2006, 12:46 PM
i just think those kenwood amps r little bitches to tell u the truth, lol,,, i've heard reviews about how there kenwood amp always cut out and they had 2 subs hooked up at w.e 2 ohms,, like mine,, and it always cut out,, but they bought one 2 ohm powerful sub and hooked it up and it never cut out so who knows im not worrying about it,, if anyone wants to buy those 2 kicker comp vrs in the kicker ported box factory,,, pm me,, i want 3 since i rarely use it ,, had them for a couple months
POST
05-02-2006, 01:05 PM
whew good thing notladstyle steered me away from those then ;P.
sell my USF books and Alpine monoblock here i come!
Notladstyle
05-02-2006, 01:44 PM
I cant understand half of that but from the half I do understand you are angry that your amp is going into protect mode and is not getting hot at all.
1. Amps dont know how powerfull your subs are.
2. The 9152 will go into protect if you have the voltage gain set to high sending a clipping signal. A 4v headunit should have the knob at 40% an 8v should have it all the way at minimum volume.
3. With a 1000wrms amp you might just be pulling too much juice.
4. Kicker CVR subs can handle a lot more than that kenwood amp could throw at them.
5. You can get two 12" Kicker CVRs in box brand new for 200 on ebay.
TBSpyder
05-02-2006, 08:21 PM
Try wiring them at 4ohms.
XScarAudio
05-07-2006, 10:04 AM
Agreed. Amps go into protect mode before blowing fuses b/c sometimes, a fuse is too late. If your impedance is too low for the amp, it will protect almost immediately. wire it to a highter ohm rating.
Notladstyle
05-07-2006, 10:23 AM
that amp is rated for 1ohm output, but that poster it not the brightest anyways, see his related thread for more info.
samakaballer
05-07-2006, 12:42 PM
lol,, the specs put it,, rms x 1 ohm = 900 rms,, rms x 2 ohm = 900 rms , rms x 4 ohm = 500 rms,,,,, so im deffinately not wiring to a lower rating,, i had a kenwood amp before this that only ran at 4 ohms,,, nothing lower and it worked fine at 4 ohms i knew i needed a diff amp that ran at lower ohms so i purchased this amp ,, obviously for this reason,,, but for some odd ball reason it's not cutting out like it did almost every 2 min's,, now it takes about 30 min's ,, i didn't really do anything different i just put them in a sealed box and did the same wiring,,, everyone i know wiht kenwood amps tell me how weird they act ,, im st arting to figure out why,, next week im hooking up 1 more comp vr to this amp ,, 3 kickers at 1 ohm ,, this amp can handle one ohm i wanna see what it sounds liek,, but i have to purchase the box that holds three next week
TBSpyder
05-07-2006, 01:05 PM
And exactly how do you plan on wiring 3 subs @ 1ohm?
POST
05-07-2006, 01:24 PM
he's retarded and refuses to accept outside help
samakaballer
05-07-2006, 03:35 PM
lol,, i forget it's on my kicker wire diagram though,, all on paper,, it even showed you how 2 wire 4 kicker comp vrs at 1 ohm completely,, just watch,, i'll show u a diagram later,, but,,, using my 3 dual 2 ohm voice coil subs,,, just trust me i have the diagram in my glove compartment,, it's pretty amazing the possibilities when kicker let's you have diagrams off t here site on wiring subs,, if you wire 3 dual 4 ohm voice coil comp vrs,, that would all equal 2 ohms.. lol,, i guess you guys never heard of this,, well just go to the kicker website and look at manuals for comp vrs,,, look for a wiring diagram it'll show you ... i thought i was the dumbest in the world at this,, but when ppl start saying im a total idiot sayign i can wire 3 2 ohm dual voice coil subs 2 equal 1 ohm,, now i feel smart again,, im out
TBSpyder
05-07-2006, 04:15 PM
Yes, please educate us on how to wire 3 subs @ exactly 1ohm. This should be entertaining.
samakaballer
05-07-2006, 04:57 PM
not goint out to my car to get the diagram,,, i'll literally take a picture of the diagram tomorrow and post it on here ,, trust me ,, what's gonna kill you is that u can wire 4 of these babies at 1 ohm,, but that woudn't work out well for me considering my amp wouldn't put out the power to realy get all i can out of the subs,, but yeah wheni say trust me ,,, that means trust me ,, i wouldn't lie about stupid shit like that ,, no matter how stupid i was at car audio. not really sure how much louder it's really going to be on this amp,, probably not much maybe a lot idk,,, just to have 3 working in my huge ass trunk will sound a little bit better i hope and look a lot better
Notladstyle
05-07-2006, 05:02 PM
So if I download a bunch of kicker wiring digrams it will make me a pro LMFAO.
(3) dual 4 ohms subs cannot give you a nominal impedance of 2 ohms.
8 8 8 - 2.6
2 2 2 - .66 ohms
Even if you did something stupid like wire one to two ohms and the other to 8 ohms you STILL wont get 2 ohms in the end and you will end up knocking one speaker off phase with the others.
samakaballer
05-07-2006, 06:56 PM
i have 3 dual voice coil " 2 ohm subwoofers" ,, and yeah you can get that out of DUal 4 ohm voice coils... i have the diagram that shows this... amazing things happen when you have diagrams to ,, like wheni hook up 3 dual 2 ohm subs to equal 1 ohm you will see lol,, i'll go to this audio meet whenever it is to show u 3 subs hooked up 2 one amp 1 ohm
samakaballer
05-07-2006, 06:58 PM
I didn't say that would make yo ua pro,, i said coming from you guys that think you are pro's i find it a bit amusing that you think wiring 3 subs or 4 subs@ 2 ohms each to 1 ohm impedence is insanity and impossible,,, oh well all that matters r the facts right,, and facts r ,, that im hooking up 3 at 1 ohm whether you believe it or not ,, and when it works ,, you can believe that or not who cares all that matters is that it will work and that it's one ohm,, and my amp is stable at 1 ohm end of story
samakaballer
05-07-2006, 07:16 PM
oh,, and where the hell do you work notladastyle ,, circuit city??? :lol: :lol: :lol: :lol: :lol: ,, because you sound just like there staff ,, bunch of morons that dont know shit about car audio,, stupid fags told me to just wire my 2 subs this weird ass way and said they might burn up oh well just bring them back and get new one's,, and i was like wtf,, and called him and circuit city a bunch of dumb asses,and got a diagram ,, and this diagram shows so many possibilities, circuit city reminds me of when my friend used to hook up other kids systems in his garage for a couple bux,,, shit's a joke,, and you would be a great employee for the department dealing with car audio,,, i think you should go ,, i only converse with pro's and kicker associates to get facts,, i think i'll stay away from tamparacingforums for anymore advice,, because any i've gotten has been complete bullshit ( the being considered as a clown for saying wiring 3 or 4 subs that r 2 ohms each equaling 1 ohm did it,lol,,, im sitting here with the diagram lookin at ur stupid ass comments laughing,, and i dont think i will take a pic or tell you how because you dont deserve 2 know how,, just go buy another amp because it'll look cooler in your little rice burner)
POST
05-07-2006, 08:24 PM
Then why don't you ya fucking moron? Apparently these kicker diagrams and your intuition (or lack thereof) are gods of audio.
Gtfo out the forums.
Oh and good luck with your nonexistant genius wiring, i hope your fucking car catches on fire.
Notladstyle
05-07-2006, 09:01 PM
So uhhh, wheres the diagram?
//Thread ... moron
TBSpyder
05-07-2006, 10:37 PM
Are you trying to make yourself look like a fool, or does it just come naturally to you? Might want to go back and have a competent, literate individual re-read you that special "diagram" of yours because you obviously have no clue how impedence works. It's becoming painfully obvious why you're having so many problems now.
:lol: Seriously?
Notladstyle
05-07-2006, 10:41 PM
O great leader snakemoron please tell us the secret of defying the laws of physics.
