View Full Version : Ipod Interface for 2Dr 2004 Accord With/Navigation
fertigryan
05-01-2006, 02:46 PM
Anybody know of an Ipod interface that works with the touch screen Factory navigation system on a 2004 2dr Accord??????
Notladstyle
05-01-2006, 03:11 PM
not that I know of =( srry
fertigryan
05-03-2006, 10:33 PM
What about a dvd player to go with the factory navigation that plays on the screen????? or tv tuner????????
Notladstyle
05-03-2006, 11:24 PM
I researched this thoroughly and since the navigation communicates via proprietary binary code to the PCM/components it woul dbe very difficult to tap into it or hack it without details on the coding which I dont think hona is gonna offer up.
custom240sx
05-04-2006, 12:12 AM
Have you tried going to circuit city and asking about the Ipod interface hook ups for stock heads? I can't remember off the top of my head if they will work with your stuff or not.
Notladstyle
05-04-2006, 02:37 AM
that ones generic and uses fm modulation - im pretty sure hes looking for direct connection/controlling/charging
TJElite
05-04-2006, 08:11 AM
Peripheral Electronics makes direct connect IPOD adapaters...I think that is what CC sells. They use the factory CD changer hook up. Unfortunately, I don't see an application for your car. You could drop them an email, or something, and see if it is in the works. www.peripheralelectronics.com (http://www.peripheralelectronics.com)
As for the nav screen hack, check with peripheral and Nav-tv www.navtv.com (http://www.navtv.com) both make interfaces for this. The Nav-TV site shows applications for Acura, so maybe something they have will work. Basically, the Navtv device installs in the the RGB video line going to the screen, and gives you one or two composite inputs. I've used them on both Ford and GM nav systems, and they work very well.
Toby
fertigryan
05-04-2006, 08:35 AM
Good stuff man............I don't car about charging, or really even controlling the ipod. I used to have a JVC Head Unit and I used the CD Changer to directly hook the ipod and it sounded perfect.
As for all of these apps, are they fairly easy to do yourself or should I get somebody else to do it? I don't want to void the factory warranty.
Thanks,
Ryan
TJElite
05-04-2006, 09:21 AM
Thanks,
Ryan
The peripheral ipod adapters are pretty straight forward. Basically, all you do is plug it in...they provide you with the appropriate factory type plug. Hardest part is getting the head unit out of the dash. The NAV-TV stuff can be a little more difficult. Some are just plug an play, but some, like the H2 touchscreen interface require you to open up the factory radio, and make some ribbon connections. Still not rocket science, but a little more daunting.
As for voiding the factory warranty...its always a risk, but I wouldn't worry too much about it. What most people don't realize is that a dealership or manufacturer really can't 'void' your warranty in most cases. Even for performance parts, etc. There is acutally a law called the Magnussen Moss warranty act (not sure of spelling) that allows you to install aftermarket parts without voiding your warranty. What they can do is refuse to cover something when it breaks, if they think the damage was due to your modification. May sound the same, but its not even close. Example...you put the NavTV system in, and your navigation quits working down the road. If the problem is the screen, they might have a case that your mod caused it to break. In which case you'd get NavTV involved. If, in fact, their device did do the damage, there's a fair chance they'll stand behind you. Now, if the nav system dies because the DVD drive breaks, the dealership will have a tougher time explaining how your mod did that. In my experience, most dealerships are pretty good about fixing stuff, even if you've modded it.
Toby
fertigryan
05-04-2006, 08:12 PM
Toby
Even better man. Thanks for the good info.
Ryan
Miles
05-05-2006, 09:09 PM
harman kardon drive + play > all. we have them in stock at the best buy in lakeland, though they should be in everywhere by now. $199.99 http://www.bestbuy.com/site/olspage.jsp?skuId=7730066&type=product&id=1140392383763
it's wireless out of the box, but there's an fm modulator available for it for $29.99 http://www.bestbuy.com/site/olspage.jsp?skuId=7729899&type=product&id=1140392383550, plus it's got a cool little interface.
here's a link to harman's mini-site for it: http://www.harmankardon.com/drive-1/default.aspx
Even tho I have an ipod in my car, I still prefer less screens to look at when I'm driving. I'd take an aux in adapter vs a secondary screen and controls.
fertigryan
05-08-2006, 04:15 PM
Agreed.... I don't want 3 screens in one car, no thanks to the Harmon & Kardon, it's a good idea, but not in my situation. I want integration with the stock unit to minimize all the clutter in the ride.
fertigryan
05-08-2006, 04:18 PM
Toby
What about using these to links? Is this a good option????
http://www.logjamelectronics.com/sounsnhond3.html
I want good sound, do you think this is a good route???? (plus the pin connector to bypass the cd changer)
I want to keep everything the way it is, just add the ipod.
Do you know if this will work well?
Also, is the stock unit a Sony????
Thanks to all.....
fertigryan
05-08-2006, 04:20 PM
Can I disable my factory XM and put this in its place, while keeping the cd changer???
Also, keeping the touch screen????
exactly. Looking factory + working well = less appeal to thieves, smoother, and safer by a wide margin
Notladstyle
05-08-2006, 07:10 PM
it looks as if that will work for audio input, but you will still need to control the ipod from its own controls.
Content Relevant URLs by
vBSEO 3.2.0 RC5
