What timing belt do i run? (sohc)
Old Apr 30, 2006 | 05:49 PM
Derka's Avatar
TR Balla Donor Supreme
Default What timing belt do i run? (sohc)
I searched everywhere and i cant find out what timing belt i need.
Im running a y7 block with jdm d15b head. I think i just need the stock y7 belt, because i read that the d15b head is the same casting as the d16z6 head. But i cant find a deffinate answer so im going to ask you guys.
Thanks in advance,
Derek
1998 crv daily beater
Old Apr 30, 2006 | 05:52 PM
95gainfla's Avatar
smokes weed...everyday.
the timing belt should match the head, along with the hg.
I <3 RooR!!!!!!
Old Apr 30, 2006 | 05:54 PM
Derka's Avatar
Well from what i read, z6/y7/y8 timing belt is the same. As for the head gasket, are you sure it has to match the head? d15b parts are hard to find
Old Apr 30, 2006 | 06:24 PM
TampaTraps's Avatar
get big or die trying!!
sohc vtec timing belt and y8 head gasket. oh and 95gainfla you don't always wanna run the same t-belt as the head think about using a ls bottom and b16 is a b16 t belt gonna work lol
that's president hussein obama to you :gordy:
Old Apr 30, 2006 | 06:46 PM
95gainfla's Avatar
didnt think of that, i was just thinking about sohc's
I <3 RooR!!!!!!
Old May 1, 2006 | 06:33 AM
EludeR's Avatar
Yes the D15B head is the same head as the D16z6 head. The camshaft profile is a bit diffrent though. The Z6 headgasket is the one to use, with the exception of the water pump and tbelt (For a jdm D15B these would be the P08 parts off of a VX engine - D15z1) everything else would be refrenced with a Z6 part. i.e. headgasket, distributor, valve cover gasket, e.t.c.
