PDA
View Full Version : Who does stitch welding?
phantom
04-22-2006, 11:25 PM
Well I came to the point of my car rebuild were its time to get the car stitch welded. Where in the Tampa Area can I get this done?
mranlet
04-22-2006, 11:59 PM
Depending on what areas you want welded and how prepped the car is, XAT may do it. Call and ask Bill or Casey (813-875-7223)
Other than that, perhaps Bodley Performance. They've built several cages for locals.
satanshatch
04-23-2006, 01:33 AM
Taylor (Durdan) can do it for you, Sean at CFP is a great welder.. I recommed the either of them.
ImportLuv
04-23-2006, 11:14 AM
CFP is who i recommend too.
Isnt sean stitch welding on his corolla wagon?
Russo86
04-23-2006, 11:15 PM
yea taylor durden does great work, his car is stitch welded pretty damn good, but then again sean can weld something serious!
phantom
04-24-2006, 08:29 AM
What areas can be stitch welded? As the prep-work goes, I have the car completely stripped(fenders, hood, lights), engine bay has been pressure washed and cleaned, all the the sound deaden is gone.
ImportLuv
04-24-2006, 08:41 AM
You should physically see someone who does it.
Some seams are hard to explain by words.
tak
04-24-2006, 10:32 AM
You should really do some more investigating...stich welding has its pro's and con's. Know what you are getting yourself into.
phantom
04-24-2006, 02:36 PM
Well i know an important positiive is stiffer chassis and in a track car thats what im looking for, What are the negetive(s)???
ImportLuv
04-24-2006, 08:12 PM
....Weight.
Stitch welding can put on approximately 50 pounds. The weight comes from welding fillers.
Also, inorder to weld the seams together, the factory primer and epoxy will be disturbed. So very good protective coating is needed to keep the welding from rusting.
tak
04-24-2006, 08:18 PM
It will also kill any shock absorbing properties your chassis may have. You hit a wall, and you are going to take the shock, not your car.
Funk
04-24-2006, 08:45 PM
the doctor. har har har
mranlet
04-24-2006, 09:56 PM
In other words, you eliminate crumple zones.
Reduction in flex increases handling, but it also increases wear on components.
SpottedMango
04-27-2006, 10:20 AM
We at Driven Concepts do stitch welding. Attached are some pictures of our work. As people have mentioned, it's not an easy job, there's a lot involved, the actual welding isn't hard, but paint removal etc, are what takes an extended amount of time. This would be a great project to take on when and if the motor's out. While the motor's out, you can get the welding completed and also paint the engine bay at the same time.
http://store.aftermarketnoize.com/DisplayResaleImage.aspx?ImageId=125
http://store.aftermarketnoize.com/DisplayResaleImage.aspx?ImageId=123
http://store.aftermarketnoize.com/DisplayResaleImage.aspx?ImageId=124
http://store.aftermarketnoize.com/DisplayResaleImage.aspx?ImageId=126
http://store.aftermarketnoize.com/DisplayResaleImage.aspx?ImageId=127
SpottedMango
04-27-2006, 10:25 AM
Point well made, I actually never looked at it in that perspective, it's so very true.
Corner Worker
04-27-2006, 12:28 PM
very interesting points of pros and cons.....I still feel the best course of action to stiffen any chassis is a good 10-12 point cage. Attaching the body to the cage is several spots will also help a bunch. Stitch welding is EXTREMELY labor intensive, and doenst add that much strength to the car overall. I know someone that can intstall a awesome cage for about the same time and money it would be to stitch weld your car.
