View Full Version : 2000 Grand Prix
martz0r
04-19-2006, 07:50 PM
I have an 00 Grand Prix GT. It will get hot at red lights or if I sit with the engine on for an extended period of time (5 mins)... Then will cool down once I start driving. A friend of mine told me it was this thing for the cooling fan, something about a switch when you're driving the cooling fan is off, or on low, but when you're sitting it's supposed to be on high? Anywho, anyone know exactly what this is called, so I can get it online? Or should I not bother and buy a whole new fan itself? Thanks.
HeavyChevy3800
04-19-2006, 09:56 PM
There you go. Comes with install instructions and everything.
http://www.zzperformance.com/grand_prix/products1.php?id=194
martz0r
04-19-2006, 10:55 PM
Thanks for the reply buuuut....
I was looking towards more a factory thing, and that's kinda ghetto-rigged. Not a LITERAL switch I don't think, just a module or something that tells the fan to switch high or low... no suggestions?
HeavyChevy3800
04-20-2006, 12:51 AM
So you want to replace the fan relays. Look under the hood in the fuse box. Right were the Acc. (+) post is. There should be a fan relay in there.
Lincoln
04-20-2006, 02:30 AM
How hot is the car getting?
Is is getting warmer then normal or actually over heating?
martz0r
04-20-2006, 08:10 AM
Just way warmer than usual... Around 215/220, causing the engine and tranny to slip and act all funny until it cools down again :P
martz0r
04-20-2006, 08:12 AM
Alright thanks, I'll check into that.
corey r.
04-20-2006, 10:02 AM
215 is normal operating temp.
When is the last time it was flushed?
martz0r
04-20-2006, 05:46 PM
Flushed about 2 months ago. Stayed norm. for about a day then shot back up while sitting at a red light only... I'm pretty sure that it's a cooling fan relay, and are you sure 215 is normal operating temp? I thought it was supposed to be around 190 or so. It could be higher, I don't remember right now but I'll look at the cluster once I get it back.
martz0r
04-20-2006, 10:47 PM
Can anyone help me find out where to buy a cooling fan relay for a 98-06 3.8? I'm pretty sure that's the problem now. I'm searching on the internet, but can't find anything... Thanks.
HeavyChevy3800
04-21-2006, 11:58 AM
Can anyone help me find out where to buy a cooling fan relay for a 98-06 3.8? I'm pretty sure that's the problem now. I'm searching on the internet, but can't find anything... Thanks.GMpartsdirect.com Advance Auto Pars, Autozone, Napa, Dealership.
impalamike3800
04-21-2006, 01:03 PM
buy a 180* thermostat from ZZP. that will help drop temps down quite nicely. wow i didnt realize more people were workin on 3.8's aside from me.
HeavyChevy3800
04-21-2006, 02:21 PM
wow i didnt realize more people were workin on 3.8's aside from me.Yeah. Tampa area doesn't seem to have to many 3800 people. I like your sig "True Power Doesn't Whine." To bad using boost is more pocket friendly. Doing an L67 topend on my L36 block in a month or so.
Lincoln
04-21-2006, 10:16 PM
There are a few 3800 Series 2 projects in the works.
2000 GTP L67 engine
4T65E-HD
Stattama 62-1 turbo
Intense cam
Siemens 60.0 (65.0) pound/hour fuel injectors
LS1 MAF
3 Bar MAP sensor
Spearco 2-231 water-to-air intercooler
Crane Cams 8.5mm Firewires
DHP PowerTuner
2kSnakeater
04-21-2006, 11:22 PM
HeavyChevy where the hell where you when I had my Monte? Damm I could of used your knowledge!
HeavyChevy3800
04-22-2006, 05:02 AM
HeavyChevy where the hell where you when I had my Monte? Damm I could of used your knowledge! Probably didn't have my liscense yet :lol:
impalamike3800
04-23-2006, 10:08 PM
we should all get together and race sometime.
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
