PDA
View Full Version : chevy 6.0L wont start??
SUPER DUBER D-MAX
04-12-2006, 12:51 AM
ok well i thought it was this and that i got a whole new ignition switch the hole deal... ok i turn on the key its cranks up then shuts right back off..
idk what it is changed the fuel filter and everything... i mean what is the missing link because im ready to go to lakeland mud bogs and shit thing wont run...
how much fuel pressure should i be makeing???
plz help me
thanks
tyler
JM's Customs
04-12-2006, 10:24 PM
try performancetrucks.net it might help you out more and what year truck
BigTruckinMF85
04-13-2006, 02:50 PM
did you check the altinater???
1stGen7
04-15-2006, 06:42 AM
LOL mike he said it starts then shuts off... means altanator is good if it rolls over
keith455
04-26-2006, 11:37 PM
I have no idea what year truck you have but did you pull the codes from it? assuming that it has an ECU
BlackWind
04-29-2006, 06:44 PM
try some ether.if it stays running while using ether, its ur fuel.
did you push the rotor down all the way?
are you getting adequate spark?
plus it may very well be ur fuel pressure regulator,dirty injectors/jets,or a bad fuel pump.check the amperage going to and from ur fuel pump and check all relays and fuses.
Southern_SS
05-06-2006, 09:13 PM
maybe pcm needs to be relearned.
turn key to on position leave it for about 15 min. makes sure lights,radio,ac,etc are all turned off.
after 15 min turn key to off position then try to start.
sometimes takes a couple of tries. i had to do this 3 times when i repro my pcm.
BlackWind
05-08-2006, 11:10 PM
normally the pcm (when it needs to be relearned will still allow the truck to run, but it will run like a fat ass on crack with a broken leg... and thats bad.
hideinginfl
05-09-2006, 01:53 AM
or you have a factory theft system, and some how your key becane unprogramed. which is probabley what it is if it starting and stopping. i work for dodge and thats what are cars will do
Mars_302
05-10-2006, 12:49 AM
yea sounds like something with the VATS
Bigtymer
06-09-2006, 11:17 PM
sounds like your fuel pump, I had the same problem.
