PDA
View Full Version : wtb bank 1 2nd o2 sensor 96 neon anyone
96neonmike
04-11-2006, 11:04 PM
just like it says need a o2 sensor the one right after the catback exhaust mines dead so the check light says its running like crap like its running lean also i heard i should get colder plugs ?
FLNeonRT
04-12-2006, 05:14 PM
A dead o2 sensor will actually make it run rich. The o2 after the converter is typically referred to as the "downstream" because its after the convrter. I just bought a OEM Mopar sensor for $110 cause I needed it to finish my turbo project.
As for plugs, unless your heavilly modded or spray or are turboed, I'd stick with factory plugs (Champion (RC9YC) or NGK V-Power (BKR6E)).
96neonmike
04-12-2006, 10:21 PM
yeah i got some hamps in it now but like i say the egine says its the second one downstream i replaced the header one less than 1000 miles ago also it said it was running lean before i got my coil pack now its just runs rough idle and slow acceleration i could give you a list of replacing ive done to narrow down what it could be but hopefully its just that o2 im gettin one on sat if i get paid fri
