View Full Version : amp problem
relited
04-07-2006, 12:31 PM
so I have 2 12' kicker cvrs powered by a kicker kx 800.2 amp...now everything was fine until today when I decided to run it bridged. I did all of the wiring correctly, and it sounded fine but didn't make a difference. So I put it back to normal mode and now it isn't hitting anymore. Its making noises though like the subs are trying to hit (a low thudthudthud repeatedly) and whenever I turn off the car a loud THUD from the subs. Now come to find out the wiring diagram I followed had been labeled for 4 ohms...I find the same guide on crutchfield after all of this and it's for a 1ohm setup soo I dont think the amp liked that one bit. i've pulled the fuses and it's still doing this...I haven't messed with the glass fuse by the battery but it isn't blown or anything. Subs test out fine on my home system...what should I try next?
TBSpyder
04-07-2006, 02:39 PM
If anything, running the amp at 1ohm should have sent it into protect mode...but wierd things happen. If your subs test out fine, it could only be your amp or your deck. Unplug the RCAs and see if the subs still make a thud when you turn the car off.
relited
04-07-2006, 08:05 PM
yea its doing it unplugged from the headunit
hopefully I can get it fixed, if not I may just bring it to the audio meet and see if anyone has a clue what to do lol
TBSpyder
04-07-2006, 09:18 PM
Amp is fucked.
Bad times. =[
time to get a new one! thats always fun lol
relited
04-08-2006, 07:07 AM
well i dunno man it isnt doing it now ... im confused oh well ill have my friend look at it
samakaballer
04-10-2006, 11:02 PM
damn.... i got that premade sub box for the 2 kicker comp vrs,, and my dad re wire the one sub 2 4 ohms because i had a weak amp i couldn't hook both up at 2 ohms and my dad is using some diagram to hook them both up to 2 ohms i hope he doesn't fuck them up
Notladstyle
04-11-2006, 02:34 AM
theres all of two wires in the sub box, why does he need a diagram?? post pictures before you run that stuff so we can make sure its cool.
relited
04-11-2006, 06:12 PM
are the dual voice coils rated at 4 ohms?...if so running them at 2 ohms isn't healthy for them...you need to make sure they are being ran at the specified ohmage setup...follow the wiring guides on crutchfield
Notladstyle
04-12-2006, 12:09 AM
:serious: ohmage setup eh? Were you sure to calculate the proper flux capacitance rating for the specified coil transponder output level while computing time travel for 7 years? If not then theres nothign wrong with running dual 4ohm voice coils parallel into a 2ohm load.
GradeA_TireFryer
04-12-2006, 12:43 AM
WHAT............................. HURT THE SUBS - ARE YOU ON CRACK OR DONT KNOW WHAT YOU ARE TALKING ABOUT. JUST PAY SOMEONE WHO KNOWS WHAT THEIR DOING TO FIX IT...
relited
04-12-2006, 10:56 AM
TALKING IN CAPS IS CRUISE CONTROL FOR COOL:):):)
TBSpyder
04-12-2006, 12:42 PM
I'm assuming he meant isn't healthy for his amp.
relited
04-12-2006, 12:44 PM
correct and that's how I messed up my amp lol
Notladstyle
04-12-2006, 03:42 PM
Two dual 4ohm subs will supply a 2ohm stereo load which almost any amp can handle if given adequate cooling.
relited
04-12-2006, 10:18 PM
yea, apparently mine couldnt =\
GradeA_TireFryer
04-12-2006, 10:26 PM
But If They Wired The 2 Ohm Subs X 2 - In Parrell And Bridged The Amp That Is A 1 Ohm Load = Fired Amp !!!!!!!!
Notladstyle
04-12-2006, 10:44 PM
I havent seen a stereo kicker amp that wouldnt trip protect mode when hit with a 1ohm load. some are actually will trip protect when they are hot in 2ohm stereo.
but if yours didnt trip into protect its a pretty good guess its damaged of blown.
relited
04-13-2006, 06:24 PM
yea, I hope it can be fixed , i'm having someone check it out..if not new amp time
relited
04-14-2006, 07:02 AM
update, my subs are blown...amp is fine yay
Notladstyle
04-14-2006, 01:37 PM
damn depending on how nice of subs they are I would almost want the amp(kicker yuck!) to blow first
relited
04-14-2006, 10:06 PM
i feel dumb, it was my shitty cd player the whole time, replaced it and it all works now...now i just gotta get a new ground lol
passfan
04-21-2006, 02:30 PM
He should have mounted his amp under the car.:lol:
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
