PDA
View Full Version : What U Tink
GradeA_TireFryer
04-04-2006, 04:19 PM
2 Subs - Dvc - 2 Ohm Vc
What Would Be A Difference If You Were To Wire Each Subs Vc As 4 Ohm Serial And Then The 2 Subs To 2 Ohm Or
Wire The 2 Vc Together Parrell To A 1 Ohm Then The 2 Subs Serial To A 2 Ohm?
TBSpyder
04-04-2006, 04:41 PM
All that matters is what the amp sees as the ohm load. If the end result is 2ohms, it doesn't make a real difference in any other way.
Notladstyle
04-04-2006, 05:44 PM
very very very small variances in the coil's reflective voltage might cause a teeny tiny gain in power when wired parallel
but in the inaccurate world of car audio theres no difference.
mbanks21
04-04-2006, 10:51 PM
If you have two dual 2ohm subs you can wire them as .5, 2, or 8. 99.995 of the time youll have to wire them as 2OHM final
