rys
04-04-2006, 01:41 PM
Unlike some and much like others, I didn't purchase my system together.
My last car had the entire stereo stolen so this time around I vowed to leave my stereo stock, but I ended up getting a good deal on one thing, which lead to needing something else, which leaves me with what I have today.
First I will start off with everything in the car.
Headunit- JVC KD-SHX900
Front Components- Infinity Kappa 60.5CS (90WRMS)
Subwoofer- Audiobahn 10" (900WRMS)
Amp #1 (Comps) BOSS RIOT 600w (120RMSx2@4ohm)
Amp #2 (Sub) - Rockford Fosgate Punch 700S (or something like that)
I ran the components ampless for several months because I lost one of the tweeter mounts while moving (lol yes I only had one tweeter installed) but recently found a replacement which got me motivated. I purchased 60ft of 16g wire and reran the wires going into the doors (one for woofer one for tweeter) and mounted the crossovers behind the kickpanels (I made the mistake of mounting the passenger crossover [the door with the tweeter installed] in the actual door, after a few months the contacts had slightly corroded but thankfully i could clean it all off, lesson learned.)
I ran the wires to the trunk and ran RCA from the cdplayer and amped them with a cheap low quality amp (the boss listed above) and they are much louder, I am happy with the results.
If you have read this far, here are my questions.
My wiring isn't where I want it to be so I want to straighten it all out. The driver side has a 4g power wire running down it and also has the RCA for the sub and the 16g for the door speakers.
My plan as of now is to rerun all of the wires as following:
Driver Side: 4g power
Center: 2x new RCA cables
Pass Side: 2x 16g component wires.
#1 : Should I have any problems with interference with this setup?
#2 : How important is it REALLY to run wires away from the power?
#3 : What should I change next in this system?
