PDA
View Full Version : SBC nissan swaps?
vertigo_16201
03-29-2006, 03:43 PM
Anyone got any info on sbc swap into 240sx's or 300zx's?
2kSnakeater
03-29-2006, 04:07 PM
you want to drop an ls1 in one of your 300zs dont you?
vertigo_16201
03-29-2006, 07:47 PM
maybe :lol:
Mars_302
03-29-2006, 10:53 PM
Lincoln has told me a few times some company is making a kit to drop an LS1 into an S chassis, dont know about Zs. There is also kits for FC and FD Mazdas
HybridSS
03-29-2006, 10:56 PM
there was a guy by the name of Leo that had a white one running around with an LS1 about 4 years ago. He has a small cam and custom headers. That thing moved out. He said the LS1 was lighter than the stock motor. Sounds like a good swap.
Suicidal Racing
03-30-2006, 06:49 AM
damn that would be one clean swap to do.or even just a mild 600hp small block..not big cubes like a 327...hmmmmmmm
Suicidal Racing
03-30-2006, 06:50 AM
i was talking about the 300..streetfire had a vid of a 240 with a 406 in it
2kSnakeater
03-30-2006, 10:53 AM
Ghost, you n your small blocks. Small blocks make great power and guzzle some good gas, get out of that old 1970's mentality, the lsx engines makes great power by using 1/3 of the gas that a normal small block would use. Go with the lsx engines, the higher the x number the better, but the more expensive.
myltwon
03-30-2006, 11:40 AM
$300 sbc > $1500+ lsx motor
wiring for sbc > wiring for lsx motor
ease of swap for sbc (uhhh...coil...battery...done) > ease of swap for lsx
with all that said I'd rather have an lsx swapped car but it's very expensive to swap
vertigo_16201
03-30-2006, 12:36 PM
Where an I get 1 of these $300 sbc's at? :)
myltwon
03-30-2006, 12:45 PM
crack open a bargain trader
2kSnakeater
03-30-2006, 02:42 PM
Thats sooo true, a monkey could install a sbc. They basicly need 2 or 3 wires.
Mars_302
03-30-2006, 02:53 PM
350s were stuck in everything, but alot of the cheap ones were just 170 hp boat anchors. they are good for a foundation if you wanna shove cam/intake and some decent performance heads on there
myltwon
03-30-2006, 02:57 PM
if it's your first time doing a swap, an lsx motor will be a nightmare
Lincoln
03-30-2006, 03:36 PM
If you want to do some reading on 300ZX and 240SX V8 swaps. There is a lot of information in LS1Tech and Torque Central (under the RX7 V8 forum).
2kSnakeater
03-30-2006, 04:29 PM
but the lsx motor will increase the resale value of the car and be hella fast!
Suicidal Racing
03-30-2006, 05:11 PM
haha if u tune your car right they really dont eat up gas...it all depends on the hp level 2
Mars_302
03-31-2006, 12:27 AM
arent truck motors faily cheap?
myltwon
03-31-2006, 12:38 PM
plus having a transmission with an overdrive gear or two usually helps in the gas mileage thing
mustangnick88
04-02-2006, 12:51 PM
damn that would be one clean swap to do.or even just a mild 600hp small block..not big cubes like a 327...hmmmmmmmOut here in St. cloud where I live they have been doing sbc 300z's and toyota truck as long as I rememmer. My best friend had a 87 300z with a 327, ported 2.02's, tunnel ram holley 450's, and 3in side pipes w/o mufflers. You want to talk about getting looks from everyone. Had to be one of the coolest cars I've even been in.
Sneakin Deacon
04-02-2006, 07:51 PM
hinsonsupercars.com has a bolt in kit for the 240's i believe now.
grannysspeedshop.com makes a vg30/sbc motor mount adapter plate.
the only big difference between ls1's and sbc's is fuel injection and transmission as far as gas mileage goes. th350 with 3.9 gears and im doing 55mph getting 10-12mpg from my rx7. same car with a Lt1 T56 slapped on and the 6th gear would bring it up to almost 20mpg.
Lincoln
04-03-2006, 10:32 AM
Yikes, I hope that isn't your daily driver.
Sneakin Deacon
04-04-2006, 11:40 PM
shit no.
im tossing a solid rear with some 3.08-3.23 gears and a big lockup stall converter. i should be able to cruise at 65-70 comfortably, and traction/power permitting, still be able to carry the wheels.
obituary
04-05-2006, 11:04 PM
rx-7 ls1 http://www.hinsonsupercars.com/
s14 http://www.torquecentral.com/showthread.php?t=33444
Lincoln
04-15-2006, 12:41 PM
http://www.gulfgt.com/forum/showthread.php?t=5181
http://img101.imageshack.us/img101/8866/enginefrontls1z9ve.jpg
