View Full Version : Stock Boost Levels for SRT-4 04
Srt4Viper
03-16-2006, 04:15 PM
Seems like my boost is a little off lately..
Who knows what the stock boost levels are through the gears.
Nolimitslja
03-16-2006, 05:09 PM
I asked this same question a couple weeks ago got no answer from anyone out of like 30 some views. Your best bet is to go to www.srtforums.com and search there you will find it.
Off-Topic
03-16-2006, 05:45 PM
like 12-15
ACR2NV
03-17-2006, 07:58 AM
depends on conditions, variables, car, and ultimately the pcm
some car will run 10-12psi, stock some run 12-14psi and some will see 14-16psi sometimes. The pcm in these cars can vary the performance based on what it feels it needs to do to achive targeted torque output. I'll save the lecture and say it varies from car to car
Dano Moparo
03-17-2006, 08:59 AM
During normal operation the SRT - 4 turbocharger will emit a very high frequency whistle at full boost 68.9 - 103.4 kPa (10 - 15 psi) during WOT acceleration.
During throttle tip-out, the surge valve will emit a light air “woosh” noise. If there is excessive NVH or other air leak/turbocharger noises, the intercooler plumbing or turbocharger control system may be compromised.
TO identify the source of the concern, check for Diagnostic Trouble Codes (DTC'S) stored in PCM memory. If any DTC'S are present, refer to the appropriate Powertrain Diagnostic Information.
If there are no DTC'S stored, use the folling chart.
CONDITION POSSIBLE CAUSES CORRECTION UNDERBOOST - 20.6 - 27.5 kPa and turbocharger lag at WOT with some air leak noise OVERBOOST - 103.4 kPa (10 psi) or more even at part throttle (could be as high as 137.8 kPa (20 psi) or more). A "Fluttering" noise can be heard during overboost. CAUTION: Engine damage can result from prolonged Overboost. </B>Waste Gate control hose plumbing compromised/disconnected
UNDERBOOST - 27.5 - 62 kPa (4 - 9 psi) @ WOT with "horse laugh" on throttle tip-out. Surge valve control hose plumbing compromised. Repair plumbing
NORMAL BOOST - but turbocharger lag and "horse laugh" noise on throttle tip-out. Surge valve scroll and vacuum feeds reversed Reverse vacuum lines ()
UNDERBOOST - 0-20.6 kPa (0-3 psi) a WOT with loud air leak noise outside vehicle. Turbocharger may emit a "howling" noise. Intercoooler plumbing hose disconnected Inspect plumbing
Very rough idle TIP/MAP sensor hoses connected improperly or TIP disconnected
CONDITION</B>
POSSIBLE CAUSES</B> Low boost pressure, lack of power Clogged air filter Leaks between engine and turbocharger Exhaust restriction Restriction in charge air cooler hose(s) Wastegate stuck open Wastegate actuator malfunction Seized turbocharger shaft Overboost Wastegate stuck shut Wastegate actuator malfunction Noisy operation or vibration Leak(s) in charge air cooler hose(s) Intake or exhaust leaks Oil starvation Worn turbocharger bearings Damaged turbine/compressor fins Blue smoke from exhaust Oil return line blocked Engine breather clogged Turbocharger shaft seals damaged
91 TURBO
03-21-2006, 07:18 PM
i have the same prob, but its my gauge. when you shut off the car, what does the boost gauge read?
Srt4Viper
03-27-2006, 02:44 PM
it reads -2
91 TURBO
03-27-2006, 08:39 PM
it should go to 0. so, your gauge is off a few pounds.
Content Relevant URLs by
vBSEO 3.2.0 RC5
