PDA
View Full Version : I Need Your AMP Advice!!!!
kober
03-13-2006, 12:45 AM
I am just a high school student with a pretty low budget, but i do have a part time job so i do have some income (so my budget is around $200-$500 mean if u think i should spend more than by all means tell me... ) . Ok so i have 2 12inch Infinity Kappa Perfect. RMS is like 350 and PEAK power is like 1400 watts. ( more info on the sub http://www.cardomain.com/item/INFPERFECT121 ).. i am into Good or Decent Brand Name quality and loudness is a must, but i really don't know what AMP should do the job for it's price and quality? i see so many amps that i duno which one to get.. Can anyone help me out?? thanks in advance for your help.
TBSpyder
03-13-2006, 01:02 AM
There's ALOT to choose from. For a cheap amp, Alpine isn't bad. For a more mid to high end, JL makes solid products (ie, the JL 500.1). Everyone has their own personal preference though. Generally, you want to look for a mono block amp that does anywhere from 500 to 700 watts RMS @ 2ohms. Post up what you might find, and I'm sure you'll get opinions.
TIM TIM TIM
03-13-2006, 07:27 PM
are they single or dual voice coil? single just get a decent 600 or so watt amp RMS at 2 ohms
kober
03-16-2006, 01:32 AM
4-Layer Voice Coil ?
umm yea i really duno anything about car audio.. i Am very young and unwise. i got these subs for $130 for both basically i dont even know if thats even a good deal. i just read reviews on cardomain and i thought it was a good deal imo.. but yea I have a 1989 CRX and i really want everything to sound nice in my car. i want it to thump but i really dont want that annoying thumping sound.. if u know what i mean.. its pretty hard to explain it.. but yea i really don't know anything about car audio. thanks for ur help.
Notladstyle
03-16-2006, 12:04 PM
spend a little more and get a alpine mrd-m605. Everything is digital it has a very small footprint. I'll pick you one up for 250.
GradeA_TireFryer
03-16-2006, 06:24 PM
Are The New Alpine Stackable Amps Out Yet???? Anyone Have One On Display Anywhere? Looks Like A Good Idea...
kober
03-16-2006, 08:21 PM
about the alpine mrd-m605... how come i should get that one?? Just because its digital?? and how come u can get it for me for $250???
kober
03-16-2006, 11:22 PM
i was looking at this but i really dont know if i should buy this for my subs.. What do u guys think?? Please lmk thanks. Btw how does OHM works.. i see it everywhere
Infinity Reference Series REF1211A ( http://www.cardomain.com/item/INFREF1211A )
specs
Amplifier Type: Mono
RMS Power: 854W x 1 @ 4 ohms
THD at 4-Ohm RMS Power: <1 %
RMS Power: 1300W x 1 @ 2 ohms
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 12 dB
Frequency Response: 17-302 Hz
Signal to Noise Ratio: 72 dB
Fuse Rating: 3 x 30 amps
Notladstyle
03-17-2006, 08:56 PM
well digital means everything is ran by computer which means accuracy and also its computer cooled which means the fan only turns on when its needed (usually somewhere around 150 degrees) You can read the input voltage, temperature, crossover point, and gain on the little LCD screen and that cool.
I can get is for 250 because I am cool.
custom240sx
03-20-2006, 12:43 AM
Ok those subs are dual 4 ohm voicecoil subs and will not...I repeat WILL NOT take the max wattage stated which is 1200 to each 12" sub. I would run a decent 500-600 watts on them. They should be wired down to 1 or to 4 ohms...I would prefer 1 ohm if it was my setup. Then find a good mono block pushing about 600 watts to a 1 ohm stable load...good luck finding one because most good brands are switching to 2 ohm loads on their amps! I work for a car audio place and if you have anymore questions regarding car audio then feel free to PM me because I do not grace the car audio thread often.
custom240sx
03-20-2006, 12:44 AM
P.S. These subs sound much better in a sealed enclosure with polyfill. The sound pretty much like ass in a vented or bandpass box. Just FYI.
TBSpyder
03-20-2006, 12:44 PM
Or you could do without the polyfill and just build the box the right size the first time around. :D
