PDA
View Full Version : Sunroof Module with 790XV
djXternal
03-12-2006, 04:03 PM
Hey guys I just got my Viper 790XV insatlled yesterday and it has a sunroof module, my question is, is there a way of setting how far back it takes the sunroof? Because right now it takes it about 1/4" farther back then it normally should and make a slight noise once it reaches that point
78mphgpr
03-12-2006, 08:04 PM
No, It only stops when there is enough resistance to shut it off.
SickVette
03-12-2006, 09:25 PM
790 is the model number of the alarm and not the sunroof module. I do not recall which module you got but that will help. True the resistance is the determining factor but adjustments most likely can be made. If you are using a 530T dipswitches can be changed.
