rear quater window.... how to get it out?
Old Mar 11, 2006 | 10:49 AM
Philly Blunt's Avatar
TR Balla Donor Supreme
Default rear quater window.... how to get it out?
i know there is one bolt on the inside... should i run a razor along the glue thru the inside? i dont want to break them but i need to get them out... whats all holding them in?
Old Mar 11, 2006 | 11:07 AM
lunchbox's Avatar
beep boop
black tar death .. go to homedepot and get a few packs of the wood shims. and a long razorblade gimick in the flooring section used for the 4 inch scraper deal .. remove trim inside and out then start at the bottom in the middle or so cutting the black crap and every few inches insert a wood shim .. not to far or it will break just enuf to keep the black stuff seperated go one direction to the corner then then other side . then continue evenly up each side..then you can start to push the shims in further to pull it away letting th tension on the glue do the work for cuting once you get the botom and 2 sides free it should kinda swing out and up while running a razor along the glue ..then clean everything off and your gold .. you can use a good black 100% silicone to resintall them when it comes time..
Old Mar 11, 2006 | 01:40 PM
ImportLuv's Avatar
rear quater windows for what car?
I got S13 windows if you need it. They are on my shell, which will be cut out into pieces.
Old Mar 13, 2006 | 10:51 AM
OniS14's Avatar
do it BIG!!
lunchbox has a good idea...
but...to make it a lil bit easier..get a heat gun to soften that tar gasket shit
S14 parts f/s
STANZZZZZZZZZZZZZZAAAAAAAAAAAHHH
Old Mar 13, 2006 | 05:46 PM
thats what i was thinking
Old Mar 13, 2006 | 08:57 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
brick
