235/40/17
Old Mar 9, 2006 | 05:01 PM
Rotary7's Avatar
Get Down-Or-Stay Down
Exclamation 235/40/17
Is this a odd size tire?
I want to run these on the back of my car for the staggered look.
205/40/17 in the front
with a 235/40/17 in the back with more of a positive offset in the back.
I know I have to roll the fender lip,Which is no problem.
I did some research and they said the widest tire should be a 235/50/15 but going to 17,and dropping to a 40 series should compensate.
I want to run a wider tire in the back,and the 235/40/17 is only 1 inch taller than the 205/40/17
Does this all sound ok?
Do you want to be tazed?
Old Mar 9, 2006 | 06:36 PM
Chuck 98 RT/10's Avatar
Sexist
A few things will be affected going to a taller tire. Gearing for one.
Are you talking track or dragstrip? You might have some push in high speed turns.
Chuck
www.BabelMotorsports.net
www.SAFEMotorsports.com
Old Mar 9, 2006 | 07:15 PM
Tinman's Avatar
If it is for an FC a 255 40 17 will fit without rubbing if you have the correct offset and wide enough rim.
Midnight Oil Fabrication
Old Mar 10, 2006 | 12:47 AM
Rotary7's Avatar
No,its just for the street.
Originally Posted by Mars_302
Who acutally makes a 235/40?
I went to tirerack.com
Looked for a tire I want,and did a 235/40/ search and most of them had that size.I first did a search for 225/40/17 and couldnt find shit
Its a little more pricey than a 205 40 17,but I think that tire it to small for the back of the car.I never heard of a 235/40 I might go to a local tire distribitor before I buy it so i can see how they look.
Tinnman
255?What does that have to be on,a 8-9in wheel?
Old Mar 10, 2006 | 04:15 AM
Tinman's Avatar
I have both 255s and 275s on 9 inch wheels with 40mm offset and both fit fine without rubbing. A 255 will fit on a 8 inch wide rim just fine also but any narrower and you will actually lose some contact patch. RX7 Club has a few threads on tire fittment that may help your search also.
Old Mar 10, 2006 | 11:33 AM
LynxZ3r0's Avatar
///M Roady
Wow, yeah.. Surprised they make tires in that size.. very odd.. I'm going to run 235/45/17 front and 275/40/17 rear on 7.5" and 9" wheels, respectively, so plenty big tires will fit on fairly thin wheels.
Now I just gotta burn up these weakling tires I have (225/45/17 and 245/40/17).
Old Mar 10, 2006 | 12:41 PM
Rotary7's Avatar
Good info,Yeah.They will be on 40+ offset.But not on a FC FB
I think 235 is the max id go.
Originally Posted by John
that size is standard on the Evo. It is an odd tire size though.
Do you have any pics to show how wide,or the profile of the tire?
You got to check out tirerack,I have bought 6 tires from them,and they just dont sell tires,they show alot of specs on it.
I compared the 205/40/17 to the 235/40/17 and its only 1inch taller,Not to bad,I didnt check on width,which I need to do.
