Local borescope?
Old Mar 6, 2006 | 09:26 AM
jblaine's Avatar
Comprehensive
Default Local borescope?
Anyone know of a local shop with one?
[ Stage Infinity ]
Old Mar 6, 2006 | 11:08 AM
VolvoBoiClw's Avatar
Ru Noises...
for my ignorance what is a boroscope?
Old Mar 6, 2006 | 03:23 PM
jblaine's Avatar
Comprehensive
Borescope with an E.
http://en.wikipedia.org/wiki/Borescope
http://www.globalspec.com/FeaturedPr...28/0?deframe=1
They're about $2000-$8000
[ Stage Infinity ]
Old Mar 6, 2006 | 04:31 PM
Ru Noises...
well thank u sir...
Old Mar 7, 2006 | 03:23 PM
My curiosity is up. What do you want to look at inside the engine bore?
If all you need is a light to drop down through the spark plug hole
to look at the bore, mine is an instrument light bulb soldered to two
solid core 22 ga. wires, clipped to the battery.
Caution: do NOT rotate the cylinder while light is down the hole.
If you need a surgical quality tv receptor/scope like they put
up your butt, for instance, good luck on finding one. We can
however, make one from some VCR/TV stuff.........
So what do you need to look at?-Bob
Old Mar 7, 2006 | 05:41 PM
jblaine's Avatar
Comprehensive
grumpy asshole. Thanks Dave.
Bob: Well, it's a boxer engine, so the plug holes are a bit more involved to get to and not open to visibility of any sort once the plugs are out unless there's a flexible camera involved... but the goal is to examine the full surface of my piston tops. Light + flexible camera required.
[ Stage Infinity ]
Old Mar 8, 2006 | 02:46 PM
Now I understand. Boxer. Very involved to look.
Check into the pinhole security cameras attached to a VCR/DVD/Monitor. Some of them provide their own light source. Should be less than the 2 grand previously mentioned..................*if* you can't get a loaner locally.-Bob
Enlighten us. What would you be looking *for* on those piston tops?
With unleaded gas, Most piston tops only have a thin flakey layer of carbon that almost blows away with an air nozzle.-Bob
Bob: Well, it's a boxer engine, so the plug holes are a bit more involved to get to and not open to visibility of any sort once the plugs are out unless there's a flexible camera involved... but the goal is to examine the full surface of my piston tops. Light + flexible camera required.[/QUOTE]
