PDA
View Full Version : Progress on my little coupe
buck19
03-04-2006, 08:38 PM
So I was finally able to get to the shop and actually work on my car.
Bought a newer head and I'm going to rebuild it once I bring it to Cedric to resurface it and clean it up. Going to paint the block with VHT as well as paint the chasis grey while the engine is out and do a basic tuneup on the engine and suspension along with a 12v AC and heater system that will sit under the dash replacing the entire factory setup. I will finish my engine harness as well with the hacking and soldering.
As for the surface rust on some of the components, the car was in saltwater from Hurricane Charlie for about 16hrs. The flywheel has seen about 2500-3000 miles on an unsprung 6 puck HDXT clutch with a 400 mile break in period
buck19
03-04-2006, 08:39 PM
And the interior all in a good days work.
Jordan T
03-05-2006, 12:12 AM
keep it up!
JC
03-05-2006, 01:16 AM
Pics/link on the AC/Heater replacement?
taka86fc
03-05-2006, 10:26 AM
My original suspension still alive :)
go garage vegas go!!
buck19
03-05-2006, 10:51 AM
The AC and Heater set up cost around $350 for the parts. The dimensions are that of a shoe box for the heater. can't find the AC dimensions.
buck19
03-05-2006, 11:03 AM
I've been rocking it out since I bought the coupe 2 years ago.
The steering wheel is still alive too. I love that thing. I need to get a new extension though. Ill probably just get the detach. hub adapter
buck19
03-05-2006, 11:11 AM
The Nismo Power Brace started rusting before it ever saw the salt water. The Silver paint on it is extremely thin and loves to chip away.
JC
03-05-2006, 12:15 PM
Buck, do you have a link to the AC (maybe on a vender site). I want to see this thing.
buck19
03-05-2006, 12:45 PM
I'll have to look at the catalog at work tomorrow. It' might just been a swampy though. I'm gonna have to double check on it.
buck19
03-06-2006, 04:17 PM
Found out a little more on the standalone ac. You still have to have a condensor for it, it weighs quite a bit, and it takes up a bit of room. So I'll be doing the heater only and later on figure something out about the AC. Biggest concern would be making the pump motor quiet.
nismokid
03-10-2006, 10:32 PM
commin along nice I want to see it when its done.
buck19
03-18-2006, 06:54 AM
Just waiting on Cedric to get the valves in and finish the head. Any day now.
buck19
03-18-2006, 07:00 AM
I also scrapped up a 3" collector and some 4 wire GM O2 bungs from work. I have 8ft of 3" tubing sitting in my room and a 3" hole saw sitting in the car. If anyone has a new 3" resonator they want to get rid of let me know.
buck19
03-29-2006, 08:12 AM
More Parts keep coming in. So now I have a completely brand new Nissan timing set, oil pump/cover, rebuilt head, valve cover ventilation oil catch can, and subframe spacers. Just need to pick up some primer paint and scrapers and get to work.
http://www.tamparacing.com/photopost/data/500/IMG_0999.jpg
http://www.tamparacing.com/photopost/data/500/IMG_1002.jpg
http://www.tamparacing.com/photopost/data/500/IMG_1004.jpg
http://www.tamparacing.com/photopost/data/500/IMG_1003.jpg
ImportLuv
03-29-2006, 08:14 AM
hurry up and get that car running so you can work for me! :D
buck19
03-29-2006, 08:27 AM
I will, I will. Going to the chiropractors right now.
ImportLuv
03-29-2006, 08:33 AM
That's not good :-o
buck19
04-01-2006, 01:24 PM
I will be prepping my car for paint this weekend and maybe finish priming it.
http://www.tamparacing.com/photopost/data/500/IMG_1009.jpg
And yes thats a gallon of SCAT in the red can...
Since I can't afford to go to Nebraska right now I guess I will be rebuilding the bottom end too. Might do some pistons as well. Found some nice 14:1cr pistons with a nice dome that puts the thunderdome to shame. Throwing a lot of ideas in the air right now. and I have a little time to think about it.
ImportLuv
04-01-2006, 05:30 PM
nice. Help me, jonas, and racingrmps13 when we paint our cars too.
buck19
04-02-2006, 11:34 AM
What is up with you sig??? haha
ImportLuv
04-02-2006, 11:43 AM
Ask taka. :lol:
Did you get the car painted yet? pix
buck19
04-02-2006, 12:17 PM
http://www.tamparacing.com/photopost/data/500/medium/IMG_1010.jpg
http://www.tamparacing.com/photopost/data/500/IMG_1011.jpg
http://www.tamparacing.com/photopost/data/500/IMG_1012.jpg
http://www.tamparacing.com/photopost/data/500/IMG_1018.jpg
buck19
04-02-2006, 12:19 PM
This is taking some tome because I'm basically disassembling the entire car. every bit of suspension, fuel cell, fuel/brake lines, clips, everything.
buck19
04-02-2006, 12:22 PM
The wiring loom on the hood is my engine harness. I still have tons of wire to eliminate.
nismocoupe
04-02-2006, 04:03 PM
nice coupe. lookin good
Jordan T
04-02-2006, 04:37 PM
goooo mike!
buck19
04-02-2006, 07:23 PM
And I have to say thanks to Petah for hooking me up with a ride and giving a hand.
