PDA
View Full Version : cable or hydrolic clutch?
nismokid
02-28-2006, 07:49 PM
I am thinking about buying a 95 240sx and it is auto, was just wondering which clutch type (cable or hydrolic) would be better to drift with cause I might be able to install the cable clutch, but the hydrolic clutch, forget about I'll let someone who knows what they are doning mess with that. But the cable would be easier to install but then again it might snap it happend to my friend. Just wondering.
marksaccord95
02-28-2006, 10:24 PM
its hydro, and it doesnt matter.
nismokid
02-28-2006, 10:38 PM
ok, thanks and do u know how much a conversion like this costs and where?
marksaccord95
02-28-2006, 10:40 PM
too much and not worth it.
I'm Phucked
02-28-2006, 11:04 PM
^ omfg :lol: :lol: :lol:
marksaccord95
02-28-2006, 11:09 PM
what? my response or my sig?
I'm Phucked
03-01-2006, 12:03 AM
both
mranlet
03-01-2006, 10:10 AM
I prefer the feel of cable, but it's probably not worth the conversion from hydro to cable. Auto to manual conversion isn't that hard - there are already templates on the firewall of auto cars for the clutch pedal and master cylinder.
OniS14
03-01-2006, 11:42 AM
+1
auto ->manual swap was pretty easy
just alot of prep work..get the firewall cut w/ a dremal the day before and you're set
clutch is hydraulic..that's why ya need to bleed it w/ DOT3 brake fluid..
as for a clutch cable line...idk how you would retro fit that..
factory provides a slave cyl that fits and does its job pretty nicely..
you would have to retrofit/fabricate a device that would stand in place of the slave
which seems a bit too much for something that already does a good job
lmk how much you are buying your s14 for..because the 5spd swap will set you back maybe $600-700 if you take your time
get alot of friends to help you out too..buy them a pizza when its all done
i bought my auto S14 back in Nov2004..paid 3800..i shoulda bargained down to 3500
hope its around that range..my car came w/ sunroof & spoiler + a few options
4k is the most you should spend on an automatic SE model..because the conversion will take up some funds..
nismokid
03-01-2006, 03:36 PM
the s14 I am looking at is going for no less than a thousand, I have no idea why it is so cheap, it might be the condition of the body but the body is not that bad a few primer spots and needs a new front and rear bumper, and I could do all the body work. The car only has like 100,000 on it.
FC3Cturbo
03-01-2006, 03:44 PM
do it yourself, it's very easy and not worth as much as someone will charge you. Just search for the info on any 240 forum.
OniS14
03-01-2006, 04:59 PM
check title and see if you can register it.
if it runs..and drive straight..then its a great bargain! make sure its not stolen though
nismokid
03-01-2006, 06:05 PM
Yeah I will, oh yeah and some idot guy was going to buy the car for 15k after the guys who owned it had done some work on it like new body parts and paint and tune the engine.15k man that is alot and I mean a lot!
OniS14
03-01-2006, 06:19 PM
15k? they must be talking about pesos or yen...cuz i dont think that would ever happen!
it might just be the dude's friends..and they are BSing you to make you think its worth soooo much more
mranlet
03-02-2006, 11:43 AM
The hardest part of the 5MT conversion is finding the clutch pedal and line. XAT makes their own lines and usually has a bunch of clutch pedals. After you have all the parts, it's just a matter of pulling the 4AT and driveshaft, drilling a hole, mounting the pedal, routing the line, mounting the 5MT and driveshaft and bleeding the clutch out.
OniS14
03-02-2006, 12:01 PM
drilling hole - 15min..it was cake
mounting pedal - 30min..a slightly annoying
routing line - no point in trying to make it fit all those damn clips..just ziptie it to the other hardlines
auto d/s - easy to remove
auto tranny - a/t fluid sucks..and torque convertor bolts are a PITA
m/t mounting was a bitch to align
bleeding clutch lines took forever because i didnt realize that when i let the pedal up...it sucked up air..making bubbles..:mad: took a few minutes once i realized that
buy a complete kit..so you get the lines..
dont forget to ask for m/t bolts..flywheel bolts..and press. plate bolts
or else you will be making a nice trip to ace hardware..:lol:
buck19
03-02-2006, 05:02 PM
dont forget a new pilot bushing. Also instead of using a dremel go to harbor freight and buy a mini air drill, drill bits, and a 1 3/8"(?) hole saw. You can do it in less than 4 hours easily. You also need a MT Tranny brace, MT flywheel bolts, an a couple of other things.
