PDA
View Full Version : Dead Speakers????
BitbyStreetRacin
02-19-2006, 06:15 PM
I have tried 2 different head units in my integra, both of which turned on and worked perfectly, just the sound wasnt playing. I checked my connections and stuff, everything checks out.... I was wondering, I got the car with the speakers in it, is it possible that the speakers are all complete garbage? Or is there something else obvious that Im overlooking? I know the head unit works, but Im not sure about the speakers. Kinda wierd that its ALL 4, and theyre not even TRYING to vibrate/make sounds.... Please help I need my music back!
Notladstyle
02-19-2006, 07:20 PM
first use an ohms meter to ensure you are getting 4ohms from each speaker at the harness. Then take a 1.5 volt battery and put the speaker leads to either end and listen for a click.
SickVette
02-19-2006, 08:23 PM
What year is the car? Did you remove a factory head unit and replace it with an aftermarket? Did the speakers ever work?
BitbyStreetRacin
02-20-2006, 09:01 AM
Yes its aftermarket head unit, and my friend had the shell before me and he had his own headunit and everything worked for him, and that was like 2-3 months ago.
notlad-thx ill try that after work today
03AcuraCLTypeS
02-20-2006, 11:50 AM
RCA's could be bad
TBSpyder
02-20-2006, 01:43 PM
RCA's could be bad
Don't think he's running an amp.
I'd pull a door panel off, pop the speaker out and test it right at the deck. If you don't have immediate access to a multi meter. It's either going to be bad wiring, bad speakers, or a bad internal amp on the deck.
GradeA_TireFryer
02-20-2006, 02:00 PM
put power to the power antenna wire see if there is a factory amp in there
BitbyStreetRacin
02-20-2006, 05:38 PM
In a 91 Integra? I guess its possible I dont really know...ill have to figure out which wire is the power ant. wire. Also, the last owner ripped the antenna wire out from under the dash, I had an extra one, I plugged it in the deck and grounded it to the frame to see if that was the problem, it wasnt I guess...
Notladstyle
02-21-2006, 12:20 AM
power antenna wire should not be grounded. There is no stock amp in a 91 teg. did you test with an ohms meter? shoot me a PM if you are near the zephyrhills area I dont have classes tomorrow so I'll be in north tampa on a job.
