PDA
View Full Version : T-stat?
Nolimitslja
02-16-2006, 11:43 PM
Can you put in the 180 t-stat without having to drain the radator? Also whats the stanton part number for the t-stat?
HMCK20
02-17-2006, 12:11 AM
yes you can and the STANT not stanton number for the 180 is 29788
ACR2NV
02-17-2006, 07:31 AM
correct brotha...
Stant 29788
SpringHillSRT-4
02-17-2006, 10:01 AM
is putting the 180 in there really helpful. i have heard many people argue both ways that it helps and other say it hurts b/c you car was made to run optium at 200.
Nolimitslja
02-17-2006, 10:10 AM
Thanks guys rep points for both you guys if you even care and sorry about that mispelling I couldn't remember it exactly I knew it was something like that :D (I just got home from a long day at work. Also I took a picture of where I think the t-stat goes if I'm correct someone just verify it for me I'm trying to make this as simple as I can for my self, I've only done one t-stat before and it was by a hayes manual so anyway thanks for the help again guys.
bluelighting
02-17-2006, 11:24 AM
You are correct. It's quite easy to do. just put a bucket under your car where the T-stat is, becasue you are going to leak a shitload of coolant. All you have to do is take out the 2 black bolts, and remove the t-stat, then use the stock gasket, and put it back in, then refill coolant. I think it took me like 15 minutes max.
Mike K.
02-17-2006, 02:56 PM
Hes correct..Always good to add a little Distilled water and you should be good..Dont be suprised if it leaks a lil for a couple days after cause I added mine and then the over-flow spurted a little out cause I added too much water..
Mike
HMCK20
02-17-2006, 03:51 PM
actually if you use a hose clamp tool on hose from the rad to thermo housing you wont loose more than a few ounces of coolant. make sure you purge the system after you install the stat.
now on the temp gimmick, some reasons your motor needs to run at a ceratin temp is for the material that the block and such is made of. its kinda hard to explain but at ceratin temps metal becomes more "slick", oil temp, and lots of other reasons. but in reality you may have a 180 stat but the car still runs around 190 so watch out 10 degrees is gonna kill your motor. but you also dont want to go to cold. another thing you might want to do is the fan switch mod. hope i explained it good im sick as hell so it might not make sense
Nolimitslja
02-17-2006, 04:33 PM
I hope you meant to say 10 degrees ISN'T gonna kill your motor cause I did it already and I only lost a couple ounces cause I wore some gloves I have for yard work and just pulled the hose off and tilted it up as quick as possible and didn't lose much at all just what was in the housing. It was easy and took me a total of about 15 minutes tops thanks for everyones help it's much appreaciated.
HMCK20
02-17-2006, 05:01 PM
lol yes, inst was what i ment to type
