PDA
View Full Version : antivenom ?
djzstang1
02-14-2006, 03:10 AM
Anyone know the # to ANTIVENOM?
U TOSLOW
02-14-2006, 03:24 AM
Greg - (813) 655-8267
djzstang1
02-14-2006, 03:25 AM
cool, thanks.. do they do t56 rebuilds in house?
U TOSLOW
02-14-2006, 03:32 AM
I am almost certain he can. That mofo knows all. So did you get your steel shift forks and hardened gears? If not there is no point in rebuilding a T56 back to stock.
Country Boy
02-14-2006, 10:19 AM
I wouldnt say that.... My friend had a motor put in there and now its FUBARed.... I used to recommend him firsthand untill what happened. I would contact Transmission Physicians 813-835-8728. It takes a lot to impress me and Fernando has done it.
corey r.
02-14-2006, 12:08 PM
TP is a very knowledgable shop.
CRT is another great place!
U TOSLOW
02-14-2006, 07:04 PM
I have just never had any bad experiences with AV, that blows about that motor. But hey shop around it never hurts. What let go in the motor?
uyht
02-14-2006, 08:06 PM
country boy who is your boy whos engine got messed up? Greg rocks and does awsome work,
Country Boy
02-14-2006, 08:13 PM
I dont want to drag him into this...
-three rocker arms not connected to the push rod or valve
-one lifter had broken into pieces
-one severly bent pushrod
-one missing pushrod
-and one of the bolts to hold down the valve cover was also bent
The motor was babied because he was told the tune was off and not to romp on it. I can verify this because he wouldnt even rev it when I asked him to before he found all this stuff.. Also, he lost compression on a cylinder or 2. Now, let me state this, this was a factory crate motor and was installed by AV. IMHO, If im installing a motor, Im going to check it out especially after he complained about it and then let him keep driving it. I dont know what exactly AV installed on the motor, but its just MHO.
uyht
02-14-2006, 08:24 PM
well it sounds like he had a bad experience for sure. That sucks. In my experience though greg is as honest and hardworking tech as there ever was. If there was something done incorrectly I would be extremely suprised to find that greg didnt do everything in his power to fix the issue, if he was made aware of it. He and frctom are a great pair and it is hard to find a shop that is more down to earth and less condescding than those two.
djzstang1
02-14-2006, 09:54 PM
Tried calling Greg today.. got awnsering machine, left a message but he never called me back....:dunno:
Boostin97SE-R
02-14-2006, 10:08 PM
You cant blame a motor falling apart on the installer. He didnt build the motor he just put it in. Now if the motor was purchased through him I would expect him to take care of it. But if it was just a motor brought to him to install he should not take any of the heat for the internals failing. Thats not caused by dropping the engine into the chassis.
Boostin97SE-R
02-14-2006, 10:10 PM
also try his shop at 661-9000
1Bad00SS
02-14-2006, 11:14 PM
Dj call the Transmission Physicians 813-835-8728......they wont let you down that I can promise you
Country Boy
02-14-2006, 11:21 PM
to me, when one accepts the responsibility of installing a customer supplied part (I dont know if it was or not), its the shops deal to check it over. When he was told about the problems the kid was still told to drive it.
stroke it
02-17-2006, 09:09 PM
i wouldnt blame the shop for that. id blame the company that built the motor. crate motors are for people who dont know how to work on thier own stuff anyway so they should have everything right. when you bought the computer your typing on did you open it up first and make sure everything was in there and all the screws were tight or did you just plug it in and turn it on?
if they did screw him, then theres probly more to the story then you know cause all the shops i know of wouldnt do something like that to just anybody. and why didnt your friend just do the instal himself?
