View Full Version : Suspension gods (sub 1.6's) Need some help here
bitemark46
02-11-2006, 04:18 PM
Read this thread. Squat is good or not good? -Mark
http://www.tamparacing.com/forums/ford-tech/287549-good-launch-shocks.html#post2950319
10secgoal
02-12-2006, 11:07 PM
Not good. I knocked off .02 (60 ft) on average when I got it to stop. Anything that is not moving the car forward is a waste, squatting, lifting the front end. There are compromises though. Some need the weight transfer to get traction. But if you are dead hooking, it would be a complete waste to put in 90/10's. Your 60 would be worse after that.
It is also possible to get your front end to rise too fast.
As I stated in there its just a loss of foward momentum ...
A hard hooking car will just slightly rotate lift the fronts and carry themm through the 60 or past depending on power
Little Nicky
02-13-2006, 01:47 AM
glad you posted it here.
01_Ram-Air
02-14-2006, 02:04 PM
You're right Mark, you don't want squat, you want the "tires" to take the hit.
evocrazy1
02-18-2006, 12:01 PM
well, when you can only get so much traction from small tires you might want it to squat. i run 26's and i need it to squat a lil to get traction, and specially when i'm on dr's
vBulletin® v3.6.10, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
