View Full Version : head studs
HPNOTIQracing
02-10-2006, 04:47 PM
im running just about 14.1-1 compression and i im getting headstuds. will oem be sufficiant or should i go with arp or something and why?
Josiah
02-10-2006, 05:13 PM
14:1 compression? is that even possible? the most I have ever seen in a neon or 420a engine is 13.5:1 and I would DEFINATLEY suggest headstuds at that cylinder pressure, (although on second thought boost probably creates just as much pressure and headstuds arent needed for it)
HPNOTIQracing
02-10-2006, 05:39 PM
i have 12.5-1 pistons decking the head .045(.045=1.125 points of compression. ) 13.625-1. i was contemplating removing the middle layer of the headgasket which gives it another half point
Josiah
02-10-2006, 07:13 PM
careful of valve clearance then, otherwise you may have an unpleasant surprise...I say keep the middle layer, 13.6:1 compression is enough(your starter will thank you)
HPNOTIQracing
02-10-2006, 08:46 PM
yeah the middle layer was a possiblility. but im puttin tomuch money into this bitch to try and risk this shit. yeah and do they sell a stronger starter if the stock cant turn it over? also do you think 93 will be high enough?
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
