Help!!!!!!
ok ill re type it basically yeterday i hydroplanned and i pressed the clutch
really hard when i down shifted i got scared lol so after that it smelled lke
burned rubber or some thing of that style , since that momnet i feel no
pressure on my clucht pedal i think it was the master ylinder because i have
fluid all over my shoes and i just notied it so can anyone please help me. hop
u under stand this better.
Try retyping that whole post and then ask again.
From what Ive read, check your clutch fluid to start off with. Then try bleeding it or something.
If you were more coherent with your post I might be able to help more.
His post is a bit confusing, but there's no need to be rude about it. Just tell him you are having a hard time understanding what he said.
It sounds like you've blown the seal in the master cylinder. I'm not sure how the layout is in 2g cars, but look up under your dash above the pedals and try to locate the source of that leak. If it's coming from the clutch master cylinder, which it pretty much has to be from your description, your best bet is to replace it with a new OEM mitsubishi master cylinder.
