polyurethane w/ out balance shafts?
the brothers told me that if i use polyurethane mounts and since i have no balance shafts, that it will vibrate like crazy high up. is this true? i dont get any vibration high up now, but can someone confirm this, oh and if i want the stock mounts, then i need a rear roller mount, can someone help me get one *******ASAP.*******
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
it did not vibrate a lot in the 2.0 the 2.0 vibrated less than the 2.4 so what i am trying to say is it will vibrate but not as much p.s. this is the brothers on darios name
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
-Dario
so if i got polyurethane, the vibration wouldnt be bad? cause i cant find any oem mounts. unless someone on here has any?!?!
Srqspeed.com
-Dane
What do you think you drive? A lexus?
Vibrations are fun, sometimes if it does it enough, certain passengers can get off! haha
God save me, Im soo bored at work.
I cant give you first hand experience but it cant be too bad... Maybe try finding someone that has it done and sit in their car and see what its like and if youd be able to live with it.
Originally Posted by DsmInduction
screw it im gettin them
lol
from a personal opinoin.....i built my motor with prothanes and no balance shafts. it vibrates alot at idle and a little more as you are letting out of the clutch, but once you hit higher rpm's it is all good. this was also in my gutted out 92 laser, which didn't weigh much. i think the more mass you car has the more it will soak up the vibration. just my .02
TEH WHIPS!!!
I have a BIKE 06 Cannondale Prophet.
2002 EP3 Civic SI
originaly posted by 57trim aka Jazz
MOTHERBITCHFUCKSHITDAMN!!!!!!!!...........DIIIIG!! ! BITCH!!! DIIIIG!!!
2002 EP3 Civic SI
I rode in imdeadsexy's car last night and he has this exact same set up. he told me the trick is to set the idle at 1000 and you are good anything lower and he said screws were starting to fall out and stuff. overall the experience wasnt bad at all. and going back to what ender said we have sports cars man you dont need a smooth ride.
-Dario
-Dario
