View Full Version : fuel in oil!
roracer70
01-26-2006, 08:58 AM
ok, so im not sure if im s.o.l. or not. i noticed quickly, and last night we changed the oil and replaced the mechanical fuel pump- and it was the cause for sure.ran the engine a couple of times and it was fine,a little gas leak but we fixed it quickly. but now my oil pressure linewent passed 100 and is pinned at the needle. its an autometer c2 with an electric sender. did the gas screw up the sender???
Frankie
01-26-2006, 09:27 AM
There's no way replacing a fuel pump changed your oil pressure at all, assuming this is an SBC you're running. Most likely, your sender freaked out or you bumped a wire off of something while you were in there. At 100 PSI, you should have blown a few seals by now. :D
roracer70
01-26-2006, 09:29 AM
actually, now there is smoke coming out of the drivers side exhaust,nothing it leakin on the outside. but the gauge, i flipped it upside down when i turned on the ignition and it fixed itself. and it reads good 40, and when i press the accelerator it moves smoothly. but like i said, now it smokes from the driver side exhuast.
Dano Moparo
01-26-2006, 10:00 AM
Is it maybe a raw fuel smoke? Maybe its just burning some residue off. That or the fuel washed the rings to the point that they no longer seal. I'd drive it a few days and see if it clears up.
Frankie
01-26-2006, 11:06 AM
Yeah, what color is the smoke?
roracer70
01-26-2006, 11:27 AM
the smoke was white. and i know its kinda cool out today, but the car never got passed 160 degrees. the smoke stopped.but im still a little nervous to punch it from a light. but if it does something crazy i'll post it lol. O, btw frankie, i think they were 16 at the time.
Frankie
01-26-2006, 03:57 PM
How long was the car off? Could just be condensation in the mufflers from all the wacky weather changes lately. If it's got a 160 stat, it's been cold enough out to keep it at 160 degrees lately.
16? Man, I wanted to come over a few times and just pull my shit out. I think they would've hit it like a bass on a top water lure.
CanTheWhales
01-26-2006, 05:20 PM
You're full of incredible analogies....Awesome
roracer70
01-31-2006, 02:45 PM
ok, its been a couple of days, my freakin gas line got cut by the alternator bracket, replaced it. but it still smokes out of my valve cover breathers. no smoke outa the exhaust and it misses sometimes. any ideas?
Dano Moparo
01-31-2006, 03:44 PM
You got some blow-by. Do you run a pcv? How many miles on engine? Maybe time for a rebuild.
roracer70
01-31-2006, 04:26 PM
the engine is only 2 1/2 years old, crate engine from gm. all new parts when we put it in. there is no pcv valve, i could never get a good seal so i had a vacuum leak, put another breather in its place and no backfire. and it has never smoked from the valve cover breathers before this whole fuel thing. and maybe 20 thousand miles. maybe...
Dano Moparo
01-31-2006, 04:39 PM
I had a lot of oil blow by after I rebuilt my engine until I put a pcv on it. I don't have any idea why it would start doing it only after you had fuel problems. A lot of gas dumping into the cylinders for a long time will hurt rings, but I dont know what it would do to the valve seals. I find it hard to believe that it needs new seals. I would try again to get a pcv system to work, that may be all you need.
EngineBuilder
02-17-2006, 11:29 PM
gasoline which leaked into the crankcase is going to leave a lot of residue, causing the oil to burnoff at a greater rate- You've already changed your oil once, change your oil again after 100 miles, and again after another 100 miles; continue to do so until the burn-off has subsided.. This shouldn't cause any long-term damage, but take it easy on your car in the interim.
You may want to try an oil additive such as lucas oil, or engine restore (something that will add detergents and increase the viscosity).
Keep us updated on your progress!
-EngineBuilder
EngineBuilder
02-17-2006, 11:31 PM
BTW, sweet camaro!
roracer70
02-19-2006, 12:47 PM
thank you. yea, probably should do another oil change by now lol.
vBulletin® v3.6.4, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by
vBSEO 3.2.0 RC5
