PDA
View Full Version : 87+88 RX-7 Parts for sale
thwam
01-25-2006, 03:52 PM
[EDIT] I do not want to sell these parts individually! I want to sell them as a lot! Price lowered to $350!!
HI. I have pretty much all the parts from a 88 SE and some from a 87 base model sitting at my parents house and I need to get rid of them. Since I haven't sold anything before on this board, I can understand the aprehension some may feel about buying from me. I am an active member of the MR2 community and have a high trader score over on their forums (www.mr2oc.com username: thwam) and on ebay (username: thwam). If you live in or around Tampa, feel free to contact me and come over and check out the parts. If that's still not enough, something else can probably be worked out.
Here are some of the parts (there are still some more that I need to catalog) and their condition. I have no idea how much they are worth, so if it's a reasonable offer, I'll probably take it.
Fuel tank - good - local picup only
Grey headliner (sunroof model) - excellent
Grey dashoard - excellent
Plastic storage bin support piece - ecellent
Blue storage bins - good
Sunroof asymbly - (don't know if motor works/paint chipped on roof)
Grey carpet - bad (although it could be died) - local pickup
Rear hatch - scratches on black paint, little tears in tint, excellent otherwise
Blue passenger side rear carpet - fair
Blue driver side rear carpet - fair
Fan blower asymbly - bad motor but has all the connectors, solenoids, etc
Instrument cluster - 123404mi, crack on lower left glass, oil pressure needle below 0
Grey passenger arm grip - excellent
Blue center console - plastic around holes on bottom cracked
Grey driver side speaker cover - excellent
Driver side leg air vents - excellent
Cigarette lighter interior piece - good (corrosion around plug, but could be cleaned)
Grey seatbelts - excellent
Engine mounts and misc bolts - ?
Trunk release - excellent
Side door vent (when you open the door) - excellent
Rearview mirror - excellent
Passenger side rearview mirror (manual) - excellent
Grey glove box - excellent
Sunvisors - excellent
AC controls - excellent
Driver side rearview mirror (manual) - excellent
Left taillight - black paint scratched, lens excellent
Grey driver side armrest - excellent
Right taillight - black paint scratched, lens excellent
Shifter surround - excellent
Instrument cluster housing - excellent
Hatch release cable - excellent
Driver side inside door handle (manual lock) - excellent
Dome light with sunroof control - excellent
Grey ashtray - excellent
Driver side door handle cup - excellent
Turn signal control box - excellent
Wires and wireing harness - ?
AC ducts - excellent
Rear liscense holder - excellent
Air pump hoses - ?
Blue hatch latches- good
Center lights - fair
Battery tray - corosion from batter but good
Left headlight motor - good
Hatch lock - good
Right headlight motor- good
Radiator overflow tank - good
Oil pump - good
Brake vaccum booster - some rust but good
Front parking lights - foggy but good
Windshield washer tank - good
Relay under upper ignition coil - good
Hood latch - good
Ignition coil for lower plugs - good
Gas pedal and cable - excellent
Belt pulleys - excellent
Brake master cylinder - corroded but good
Right rear caliper - corroded but good
Subzero unit - good
Left front brake caliper - good
Air pump - good
Pressure sensor - good
Carbon fuel filter - good
Left rear caliper - good
2x brake rotors - good
Air cleaner asymbly - good
Gas tank filler and gas sender unit - corroded filler but good
Door handle levers - good
Power antenna - bad motor
Drive shaft - good
Wiper arms - rusty but good
Cat converter - ?
Line from clutch cyl to slave cyl
Axles - good
Main vaccum to brake booster line - good
Heat shields - good
Engine - ???
I was trying to sell these in June of last year, but I had some heart problems and ended up not selling anything. I would like to sell everything together, as these have been at my parents house too long, and selling one item at a time is too much of a hassle for me. I will let these all go for ~$400 obo. As everything is already taken off the car and boxed up, you could resell these and make some money out of it, or just use it for backup parts for your car. Thanks!
Todd
Sneakin Deacon
01-26-2006, 12:09 AM
do you have the plastic trim piece for the radio support and all that center part?
thwam
01-26-2006, 11:23 AM
I want to say no because I believe it was cracked like every other RX7 in the world. haha
Todd
AbortRetryFail
01-26-2006, 11:32 AM
This is the black 'cowl' part that attaches to the gauge cluster and holds the turn signal/headlight switch/cruise control/wiper switches etc right?
How much do you want just for that?
s14monkey
01-26-2006, 11:34 AM
(silvia_san) do you have the transmission crossmember?
thwam
01-26-2006, 01:00 PM
AbortRetryFail yes I do have that piece and from memory, it's in very good condition.
s14monkey I'm pretty sure I have the crossmember too. I haven't gone thru this stuff in a year, and it's just been sitting in my room at my parents house, so I'm not entirely sure. Could you send me a pic of what it looks like and I'll check when I go back over there this weeked?
I really want to sell all these parts in one go guys. It's a hassel for me with school and work to drive back to my parents house to get these parts. Considering some of the parts that I have I'm sure they're more valuable than what I'm asking, and again, I'm flexible on the price.
Todd
thwam
01-27-2006, 09:24 PM
No takers on purchasing all of these parts at once?
Todd
CrypticApathy
01-27-2006, 11:18 PM
if if its still up forsale after my tax return gets here ill do it. BTW do you have a tranny?
thwam
01-28-2006, 05:43 AM
Yup, sure do!
rawboy
01-31-2006, 03:16 PM
you still have all those, im willing to take all of it? for that price?
thwam
02-01-2006, 11:47 PM
Yes, I still have everything listed. And I will sell it all for that price! =) Would you like to buy it all?
Todd
thwam
02-05-2006, 09:45 PM
Everything's still for sale!
thwam
02-14-2006, 09:35 PM
Still for sale!
B20.eg
02-15-2006, 05:25 PM
if you have the alternator call me at (863) 514-3194 and i will come get it. 35$ let me know asap. -nathan
RB240Mike
02-19-2006, 01:05 AM
Do you have a transmission?
thwam
02-22-2006, 09:42 PM
I do have the transmission, but since the motor never ran, I don't know its condition.
All the parts are still for sale guys! I need money for my V6 MR2 Turbo project...help me out!
Todd
flubyux2
03-18-2006, 05:01 PM
hey do you still have the bodies? im lookin for a front driver fender and a rear passenger quarter panel. im also interested in the blue bins and a blue rear carpet if youve got it. do you have blue rear speaker grills, or at least the driverside blue rear speaker grill? also, do you have the rear speaker mounting rings that screw into the strut tower?
PM me and let me know what you still have.
thanks
chris
thwam
04-06-2006, 02:28 PM
I do not have the body..just the parts. And again, I do not want to sell these parts individually! I want to sell them as a lot. Price lowered to $350.
Todd
shit_car
04-09-2006, 12:55 PM
do you have an 87 maf? its a cheap mod for my car
MasterTang
04-17-2006, 09:03 AM
I will buy that back hatch....let me kno when I can pick it up...aim me.
Thanks
George
thwam
04-25-2006, 09:14 PM
All of the parts are still for sale, AND ONLY AS A LOT!
TOBYOTA
05-24-2006, 08:58 PM
Man i really need that dash!! But like you i dont want all that stuff hanging around. I have too much stuff as it is lol. What is the least you will take for all???
MasterTang
05-25-2006, 02:00 PM
Hey please tell me you have a Antenna ??
I didnt need the hatch i thought it was in really ad shaoe uts just the latch on the Hatch that is acting up...
