Merkur xr4ti help
Old Jan 23, 2006 | 03:08 PM
FMYStreetRacer's Avatar
Default Merkur xr4ti help
need a little help for a friend. he's trying to swap his merkur from auto to 5-speed. hewas told that the driveshafts were the same but they're not. so now he's got it all bolted up and no driveshaft. he plans on removing the t9 trans soon and wants to put in a t5 when he upgrades the turbo. what are his options as far as a drive shaft go? he would rather get one that will be able to be used in both the t9 and t5 tranny if possible. is there a one peice conversion that he can do? any help will be appriciated.
Old Jan 23, 2006 | 05:19 PM
evocrazy1's Avatar
my buddy has a merkur and is using a turbo coupe driveshaft, and t-5 you have to get a 3/4 spacer for the tranny
ASKED TO BE BANNED
Old Jan 24, 2006 | 03:32 AM
yeah but will the turbo coupe driveshaft work on a t9? maybe he'll just have to have this one shortened.
Old Jan 24, 2006 | 03:56 AM
truffle_shuffle!'s Avatar
Chomsky with dick jokes!
Get a custim drive shaft thats what my merkur had. The drive shaft shop does great work... And do your self a favor and got t5
There are points in life where one looks at his or her situation and says "how the fook did i get here?" ... this is one of those instances....
Old Jan 24, 2006 | 03:20 PM
barry bledsoe's Avatar
The lost pony
I have read on some web sites that there is a drive shaft adapter that is made so you can use a mustang drive shaft it is probably the same or close to the thunder bird shaft there is also a tranny conversion crossmember I have seen them for 135.00 I dont know how much the drive shaft adapter is I believe the adapter and a used mustang shaft is cheaper than having one made. I am going to put a c-4 in mine. it takes the same conversion parts. as far as the driveshaft adapter and drive shaft. I am just waiting for the c-3 to break
Old Jan 24, 2006 | 04:38 PM
cool i just tell him to have his shortened for now. he wants to use the t9 for now then swap out to a better t5. he just wants to make sure the car works as it should when it's stock then start to mod it. hopefully the trans will last till he puts in the t5.
Old Jan 24, 2006 | 06:24 PM
Originally Posted by Just Dave
I can't imagine a thunderbird driveshaft fitting in a Merkur. That shaft is quite a bit longer than a mustang shaft. Maybe they are cutting a T-bird shaft down, but in that case, I'd have one made.
for some reason I think Rales has it that way.. best to PM him...
Old Jan 25, 2006 | 05:02 AM
Rales's Avatar
All Vacuum
I have a completly custom drive shaft. Your best bet is one out of a thunderbird, aerostar, or some other similar vehical that has the correct splin count. Once you get one either get a spacer or cut it down. Bilbo, yours I beleive is a cut down thunderbird one, or its a cut down mustang one.
AIM: SolderedLego
Toys are fun, atleast they dont say NO.
Like to drink buy a drinking tee
http://www.tampaforums.com/forums/mi...s-more-289609/
