PDA
View Full Version : Something Fishy?
813_05_STi
01-10-2006, 06:28 PM
Since I had my turbo back on my car I could never fill my gas tank completly. 3/4 was all she wrote, and I just installed OEM STi turbo back on the car 2 tanks empty to full right on the FULL Line? I have heard others commenting on this but never head a deff how come? Possibly the weight difference makes the float stick? I am using the same gas station, same price of gas, same pump even. :dunno:
fadedSTi
01-10-2006, 07:24 PM
the needle is crazy. mine does that sometimes too. ill fill it all the way up and it will 3/4 or sometime i have to turn the car off and then on again to get the needle to register
sierra3
01-10-2006, 09:18 PM
Same here. I have had the needle sit between 3/4 or 3/4 and full right after I have filled up.
StiGuy
01-10-2006, 11:19 PM
At least in my experience, I think it's coincidence it was ok once you went back to stock tbe.
I had this exact same problem when my car was bone stock, no changes of any kind on the car. The dealer replaced either the sending unit or the fuel pump, I forget which, but I think the fuel pump.
It helped a lot with the problem but it still popped up occasionaly. However since going with an aftermarket fuel pump (knock on wood!) I have yet to have this problem reoccur.
This problem has occurred with others as well, just search iwsti and nasioc. Some people have found out that if you totally shut off the car (as in no turbo timer counting down or radio on) and take the key out of the ignition it seems to take care of the problem. At least some times. Ymmv. :)
Hth.
I'm Slow
01-11-2006, 12:49 AM
thats weird, must be something with the STi:dunno:
Franklin
01-11-2006, 11:29 AM
There was a thread on this months and months ago on IWSTI so you aren't the only one with this problem. IIRC, it had to do with how the gas tank is shaped?
onefast01lude
01-11-2006, 05:41 PM
i deal with this from time to time and just ignore it
813_05_STi
01-11-2006, 06:50 PM
I try its just anoying, Im comming up on my 3rd tank of gas since my Turbo Back came off. See if it does this again.
Franklin
01-12-2006, 07:20 PM
I forgot to mention this in my previous post: This also happens to me, but it goes all the way up later on.
fadedSTi
01-12-2006, 07:33 PM
thats what mine does most of the time
