PDA
View Full Version : wtb sbc heads
williamb82
01-05-2006, 02:18 AM
preferably 60's early 70's iron with 2.02/1.6 valves and the 64cc combustion chambers, though might consider the 1.94/1.5 if the price is right. if you have a set that need rebuilt thats fine, or even if they are bare as long as they arnt cracked and havent been milled a ton. just pm with a price and the casting number please. thnx.
william
williamb82
01-05-2006, 07:30 PM
also, i would consider a set of 062 vortec heads as well.
g3t_Sum
01-06-2006, 01:49 PM
i believe they are called double hump heads
williamb82
01-06-2006, 01:57 PM
or camel hump heads. heres a more specific list of what i want.
1st choice.
casting number 3991492 has 2.02/1.60 valves and 64cc combustion chambers. has accessory holes. 1970
2nd choice
casting number 3927186 with 2.02/1.60 valves and 64cc combustion chambers. has accessory holes. 1969-1970
3rd choice
casting number 3947041 with 2.02/1.60 valves and 64cc combustion chambers. has accesory holes. 1969-1970
4th choice
casting number 3973414 has 2.02/1.60 valves and 64cc combustion chambers. has accessory holes. 1970
5th choice
casting numbers 3890462, 3891462, or 3990462 with 2.02/1.60 valves and 64cc combustion chambers. doesnt have accessory holes. 1962-1968
6th choice
casting number 3782461 with 2.02/1.60 valves and 64cc combustion chambers. doesnt have accessory holes. 1964-1966
7th choice
casting numbers 3912291, or 3917291 with 2.02/1.60 valves and 64cc combustion chambers. doesnt have accessory holes. 1967-1968
8th choice
casting numbers 3917292, or 340292 with 2.02/1.60 or 1.94/1.5 valves, 64cc combustion chambers. Accessory holes? 1968
9th choice
casting number 3947040 with 1.94/1.5 valves, 64cc combustion chambers. Doesn’t have accessory holes. 1968
10th choice
casting number 3927187 with 1.94/1.5 valves, 64cc combustion chambers. Do have accessory holes. 1969-1970
Racer
01-06-2006, 09:43 PM
For your second choice you have the number 3927186. I have a set with the number of 3927185. Would they work for you? These have not been cut and are not cracked.
williamb82
01-06-2006, 10:05 PM
unfortunatly not, they have 1.72/1.5 valves and 70cc chambers. though they would raise the compression, they wont flow as well as my stock heads so would maybe give the same power.
