PDA
View Full Version : FS: Nearly new Sony CDXF7700 MP3 CD Player
SSpiro
01-03-2006, 10:14 AM
[Pictures to follow when I get home tonight]
I am selling my slightly used Sony CDXF7700 MP3 CD player. This is a mint player only used for a few months before I got my new truck. Comes with everything as I got it when I bought it (player, face, face case, remote, all wiring harnesses, brackets, manuals, etc). Specs:
Features
SSIREX-A tuner
Station Presets: FM 18 / MW 6 / LW 6 / SW 0
BTM (Best Tuning Memory)
RDS EON
CD-R / CD-RW Playback capability
MP3 Playback capability
ID3 Tag (Track-, Artist-, Album name)
CD Text
Frequency Response 10 - 20,000 Hz
Signal to Noise Ratio 120 dB
Repeat / Shuffle
Changer Control function for optional: CD or MD autochanger
S-MOSFET output stage
Output Power (DIN 45324, 4 ohm) 4x 27W
Max. Output Power (1kHz, 4 ohm) 4x 52W
BBE-MP
Dynamic Soundstage Organizer: DSO II
EQ-7 (7 Band Equalizer)
Loudness control
Pre-amp Output: Front / Rear (High pass filter)
Max. Pre-amp output level 4V
Sub Output
Low Pass Filter
Sub Volume Control
Aux. input (audio)
Display: FL LCD (Fluorescent) 8 grade blue colour
Display Dimmer
Blue key illumination
Safety Commander Interface: 3.5 mm jack
Sensor for IR Commander
Removable Front Panel
Integrated Clock: 24 h
Telephone Attenuator
Supplied ISO connector
Installation angle 0-45 degrees
Dimensions (WxHxD in mm) approx 178x50x178
Satellite Radio Ready: Yes (http://javascript<b></b>:toggleQuestion('t0','q0','a0'))The receiver is compatible with optional tuners that will receive digital satellite radio broadcasts such as Sirius or XM Satellite Radio. The digital satellite service must be subscribed to separately.
RMS Power Output: 23.2 Watts (http://javascript<b></b>:toggleQuestion('t1','q1','a1'))RMS: Root Mean Square is a formula that provides a reasonably accurate means of measuring and comparing continuous AC power. The use of this measure is preferred when matching system components, like amplifiers and receivers.
Preamp Voltage: 4 volts (http://javascript<b></b>:toggleQuestion('t2','q2','a2'))Preamp Voltage: Refers to the strength of the pre-amp outputs. Generally, higher output voltages make it easier to get a cleaner and a more noise free signal delivered to amps and pre-amps.
Subwoofer Preamp Outputs: Yes (http://javascript<b></b>:toggleQuestion('t3','q3','a3'))Preamp Output: Typically found on headunits, a preamp output provides low level, high quality audio signal for use with external amplifiers.
Maximum Power: 52 Watts (http://javascript<b></b>:toggleQuestion('t4','q4','a4'))Maximum Power: The amount of power a speaker is estimated to handle during a brief high-intensity musical burst. Since this can vary with both frequency and amplitude, it is a much less accurate way to judge speaker durability and performance than RMS.
DIN: 1 (http://javascript<b></b>:toggleQuestion('t5','q5','a5'))DIN: Acronym for Deutsche Industrie Norm (Deutsches Institut fuer Normung), the German standardization body. A world reference standard for the mounting parameters of many common receivers ( Head ends) as well as other types of cables and equipment.
Changer Control: Yes (http://javascript<b></b>:toggleQuestion('t6','q6','a6'))Changer Control: Receivers with changer controls operate same-brand/compatible CD or MD multi-disc changers.
CD Text: Yes (http://javascript<b></b>:toggleQuestion('t7','q7','a7'))CD Text: The receiver can display disc and song title information contained on CD-Text encoded discs.
Built-in EQ: Yes
CD-R/CD-RW Compatible: Yes
Remote Control: Yes
Detachable Face: Yes
Bought this for about $350, however, its online for about $200. Selling for $150 delivered. Email me @ sspiro at tampabay dot rr dot com, or PM me.
Thanks for looking!
