View Full Version : How to tell if its reflashed
smooth_ej20
01-03-2006, 11:06 AM
Well ive had my car for a little over a year now and it just occured to me that i have no idea what the previous owner might have done to it. I know he put in an UP and cat back but i was wondering if theres anyway i can tell if he got the ecu reflashed or not. Only thing i know for sure is that my boost peaks at 14.9~15 psi, but other than that i dont know if theres a way to tell. IF you guys have any ideas let me know.
HKSWRX
01-03-2006, 11:28 AM
If somebody reflashed it they would have turned the boost up, that turbo can handle 18.5-19lbs
smooth_ej20
01-03-2006, 11:36 AM
i thought so but i wanted to make sure. DOnt want to hook up my UTEC and blow some shit up.
HKSWRX
01-03-2006, 11:43 AM
you def should have a professional tune your utech
smooth_ej20
01-03-2006, 11:46 AM
well for now i was going to run TurboXS base maps for Stage 2. Once i upgrade other parts ill take it out to CFT.
USF97J4x4
01-03-2006, 02:23 PM
He musta did something, that is pretty high.
Stock boost level is more like 13 lbs @ WOT in 3rd
HKSWRX
01-03-2006, 03:04 PM
Thats on a WRX - I believe the levels on the sti are higher
mantra1
01-03-2006, 03:13 PM
For a TD04? You'll only be blowing hot air. That turbo is max efficient around 16psi. The VF39 is good for around 19psi.
HKSWRX
01-03-2006, 03:24 PM
My apologies, I was under the asumption that we were talking about an STi, I am well aware of the boost efficency of both turbos
smooth_ej20
01-03-2006, 10:58 PM
USF- even if i have a catless turbo back and up-pipe? i thought it might jump that high due to a little boost creep. If it is flashed, is there anything i can do to get it back to stock or am i up shit creek?
USF97J4x4
01-05-2006, 09:04 AM
Ive got an uppipe and turboback, still have 13 or so lbs WOT 3rd
smooth_ej20
01-06-2006, 07:28 PM
doesnt matter anyway. My UTEC will override any flash that could be there anyway so im not worried. Just have to decide when to get it tuned up
Content Relevant URLs by
vBSEO 3.2.0 RC5
