View Full Version : is this normal.....
specialk8519
12-26-2005, 12:03 PM
I just got my SRT-4 two weeks ago, so i'm kinda new to this.Anyways,when im idling it feels like its misfiring. I'm not sire if it is, or if that is normal. Let me know. Thanks.
Sounds like you may have a fouled or semi-fouled plug . Change them with NGK Part # 4306 and gap them at .035 ...
If the plugs are fouled this should be the problem and cure it ...
It could also be nothing. Due to the low compression and injectors, the srt does not have a smooth idle by nature. However, if the vibrations are anonoying its possible you have a problem.
HMCK20
12-26-2005, 07:03 PM
dont know if you bought it new or used but if you bought it used do you have a modded ignition. cause when i did coil and wires it melted my stock plugs i went to a heat range colder ngk iridiums. but dont go crazy with thinkin there is a issue cause just like cali said the srt isnt natrually a smooth idler.
SpringHillSRT-4
12-26-2005, 07:06 PM
the coil itself might be bad too. when i bought my car with 2500 miles on it from jerry ulm used the person before me put a aftermarket coil on the car. well needless to say on the way home it went bad and sounded like your problem. just take the car to the dealership and let them firgue it out. thats what a warranty is for.
Dano Moparo
12-26-2005, 11:54 PM
The tech's have been turning in some plugs with nasty carbon tracks from PT turbo's.
specialk8519
12-28-2005, 10:38 AM
Hey thanks for the help guys. I have an appointment on thuesday at Brandon Dodge.
Content Relevant URLs by
vBSEO 3.2.0 RC5
